Why is that Alex? Its only dumping 10-15 degrees of timing for 3 seconds or so. Should be interesting to see the flames, lol.
I have to get this barge off the line somehow. Craig sent me this link...
I just love seeing the stuff you come up with and actually get to work. It sure needs a hand to get off the line, maybe an extra litre would help :P
I have to slow my response down low...
No exhaust just poked the dump pipe, yerh foot to the floor.
But I can't understand y I'm stuck at 2200rpms when im trying to stall it up? Shouldn't it let me go beyond?
Not with a 2200 rev stall converter. If you want it to take off hard you went too big with your turbo, now you have to match the stally to the lag you bought yourself. Mine is a 3000 stall converter and it may be for sale soon. I will probably be heading for 3500 stall with 6 lockup clutches instead if 1. (if Kewish can sort me out with one...)
anti lag? you did not tell me of this scott :P
Cihan and I were talking about it, seeing I don't want to go too big with the stall converter and I don't want to spool the turbo with NOS I have very little choice at the moment.
Yes Alex, the 3.5 will help but that isnt getting a plain rebuild, if I ever get the funds I will be shooting for big numbers, too big for a Stagea to handle I believe. ;)
is this wire cut mod only limited to turbo stag's? what about v35s?
I have no idea, I would assume there is something similar in their ecu. Do you have a link to the ECU pinouts? I will have a look if you can find it...
I don't think that the V35/PM35/z33 throttle restriction is based off the same process as the NM35.
I believe its more of a electronic throttle table, that will only allow a specific percentage (or volts to be precise) of throttle opening at X load Y RPM. Not based off the brake signal as far as I can tell. I base this off the fact that I can alter the values in my tuning software. Anyone who has driven both cars will realise the difference.
No pic.
The VQ25dd ecu uses the same plug as the VQ25det so it should be similar but without the pinouts youre flying blind. I have the full M35 electrical book in front of me but I can't read Japanese...
I too can adjust the throttle sensitivity but the restriction is different, have you hooked up the software to see if you get 100%tps at stall? Perhaps its gone now with the re-flash?
yeah ive only got a jap version too
some v35s come with the factory snow/power switch that does the same throttle reduction/increase in sensitivity. i keep mine on snow 99% of the time but it has shown no improvement in economy... still 12.6L/100km
Snow will take off in second usually although I haven't played with the switch much in mine.
each car is different obviously, in my case it still uses first, throttle response appears to be around 10% of normal, revs stay below 2500rpm, and no kickback.
Wat?
So, you put it in snow 99% of the time, but it doesn't improve economy, so in essence your driving around a car that feels like shit for no benefit! I see no point!
The one and only time I use snow is when I'm putting the car up on ramps- because it locks front /rear torque. It will just drive up the ramp easy (obviously you don't have awd...)
Scotty, I haven't done a throttle % map, and it is different now. I have a completely different ecu, even to most of the V35's, as its a Gen 2 Ecu- Runs widebands not narrowbands from factory. But there is just no way there is the NM35 style restriction on our Ecus- stock, there isn't the torque of the turbo motor!
Wat?
i only just calculated the economy after noticing the factory economy meter hadnt dropped....
using the switch is now just to make takeoff alot smoother... as the pedal is way too sensitive on the other settings.
As Scott said its due to the stock stall converter. Should work fine for the stock turbo....well it works great on my setup...
oh ok just realised you had a 3071...hmmm yeah no boost for you LOL
  • 1 year later...
The pedal is way to sensitive....grow a set! This is a V6 not a nissan micra. Get over it or get another car
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
