I was just thinking if you used the dive circuit to complete the circuit once ot goes to either n, r, p it will reset due to tge circuit beind broken with these gear changes. With this in mind how is it with manual shift . Has anyone played with this. Are either drive or manual shift on samewiring circuit?
A quick point on the above questions, I had been thinking about the easiest/best way to achieve this.
One of my early thoughts was to use the ECU wire that sent the CEL signal. It would be sef healing - brake wire mod causes CEL, CEL output resets Brake wire input, CEL extinguishes. Win!
However, the CEL output is a 5V signal whereas the brake wire input requires 12V to reset. :(
So I had a quick scan thru convenient ECU pins & couldn't find anything suitable. Other switches are an earth on so also not suitable (not sure about all listed above).
In the end I connected mine to the reverse lights (already found for reverse camera) so reset every time I go into (or past) reverse gear.
I used the opportunity to install my 'Valet switch' at the same time, so needed a diode to stop reverse lights coming on when activated.
Josh, not sure if there's a diagram as such, but it's Pin 59 on the ECU if you have the pinout PDF.
For what's it's worth, I've knocked up a few pictures. These are very simple circuits, but sometimes a picture is worth more than a heap of text.
1. In it's simplest form. Switch required to clear CEL
2. Better because resets automatically. NB. Can use any temporary source of 12VDC.
3. Optional valet switch (anti-hoon) upgrade. Diode required so reverse lights don't come on when valet switch operated.
And lastly, the ECU diagram (again) for those who don't have it.
ECU_PINOUTS 13_12_10.PDF
Cheers, Leon.
Pin 55. Pink wire with a blue trace.
Thanks Scotty, I should have looked it up properly before posting those pics, lol. Hopefully the diagrams are still helpful to someone - just note my error & cut the right wire :)
No worries Leon.
I know a lot of guys read this thread and have a crack at it themselves, make sure you are cutting the pink/blue wire on the ECU and not the TCU as the gearbox controller is in the passenger kick panel. You will need to remove the glove box to get to the ecu plug.
No worries Leon.
You're right - even though the correct ECU pin number is probably written 2 or 3 times in this thread & many more times in others, someone is bound to get it wrong. As you've hinted, we've already seen an example of a car being sold with a switch that disabled a pink/blue wire on the TCU, lol.
Good thing is pin 59 is probably not populated in our ECU wiring, so that should cause a rethink if anyone blindly follows my drawings. But I'm still ashamed of my gaff :/
Is the wire accessable at the brake pedal?
Maybe Rich, but not sure it's that simple. One of the wires on the brake assembly emits 12V when pedal is pushed (we used this to cancel the cruise control) & I think this is used to light the brake lights (prob via a relay). But when Pin 55 is cut, the brake lights still work, so probably comes off a different control/relay. You can try it if you like - it'd be interesting to know - but since it's quite simple to find & work on at the ECU I'm not sure it's worth the effort.
It has to be cut completely so the ECU doesn't "see" 12V when you put your foot on the brake.
As long as the ECU occasionally sees 12V (approx every 400km) it won't know any different. That is why you need to either a) wire via a switch to restore the connection (put foot on brake, CEL goes out, open switch again), or b) wire to alernative 12V source that comes on during normal driving but won't interfere with you making use of the mod, ie the reverse lights.
The only restriction if following b) above is - you can't launch with full throttle in reverse, lol. I think we can live without that :)
You will need the exhaust done, it is extremely restrictive, especially the dump/cat pos. That will help spool the turbo.
Speaking of which, I may be trying out an anti-lag button for mine to help spool the turbo at stall. I will let you know how it goes. (This should work with the emanage too.)
O really!
Pin 44 is the neutral switch input to the ecu, perhaps that is a good feed to splice in to...
That could work, but I can't find any info as to what that signal is & CBB checking it myself.
The voltages from the switch to the TCM won't work (looked at those before).
Edited by Commsman
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
