I was just thinking if you used the dive circuit to complete the circuit once ot goes to either n, r, p it will reset due to tge circuit beind broken with these gear changes. With this in mind how is it with manual shift . Has anyone played with this. Are either drive or manual shift on samewiring circuit?
A quick point on the above questions, I had been thinking about the easiest/best way to achieve this.
One of my early thoughts was to use the ECU wire that sent the CEL signal. It would be sef healing - brake wire mod causes CEL, CEL output resets Brake wire input, CEL extinguishes. Win!
However, the CEL output is a 5V signal whereas the brake wire input requires 12V to reset. :(
So I had a quick scan thru convenient ECU pins & couldn't find anything suitable. Other switches are an earth on so also not suitable (not sure about all listed above).
In the end I connected mine to the reverse lights (already found for reverse camera) so reset every time I go into (or past) reverse gear.
I used the opportunity to install my 'Valet switch' at the same time, so needed a diode to stop reverse lights coming on when activated.
Josh, not sure if there's a diagram as such, but it's Pin 59 on the ECU if you have the pinout PDF.
For what's it's worth, I've knocked up a few pictures. These are very simple circuits, but sometimes a picture is worth more than a heap of text.
1. In it's simplest form. Switch required to clear CEL
2. Better because resets automatically. NB. Can use any temporary source of 12VDC.
3. Optional valet switch (anti-hoon) upgrade. Diode required so reverse lights don't come on when valet switch operated.
And lastly, the ECU diagram (again) for those who don't have it.
ECU_PINOUTS 13_12_10.PDF
Cheers, Leon.
Pin 55. Pink wire with a blue trace.
Thanks Scotty, I should have looked it up properly before posting those pics, lol. Hopefully the diagrams are still helpful to someone - just note my error & cut the right wire :)
No worries Leon.
I know a lot of guys read this thread and have a crack at it themselves, make sure you are cutting the pink/blue wire on the ECU and not the TCU as the gearbox controller is in the passenger kick panel. You will need to remove the glove box to get to the ecu plug.
No worries Leon.
You're right - even though the correct ECU pin number is probably written 2 or 3 times in this thread & many more times in others, someone is bound to get it wrong. As you've hinted, we've already seen an example of a car being sold with a switch that disabled a pink/blue wire on the TCU, lol.
Good thing is pin 59 is probably not populated in our ECU wiring, so that should cause a rethink if anyone blindly follows my drawings. But I'm still ashamed of my gaff :/
Is the wire accessable at the brake pedal?
Maybe Rich, but not sure it's that simple. One of the wires on the brake assembly emits 12V when pedal is pushed (we used this to cancel the cruise control) & I think this is used to light the brake lights (prob via a relay). But when Pin 55 is cut, the brake lights still work, so probably comes off a different control/relay. You can try it if you like - it'd be interesting to know - but since it's quite simple to find & work on at the ECU I'm not sure it's worth the effort.
It has to be cut completely so the ECU doesn't "see" 12V when you put your foot on the brake.
As long as the ECU occasionally sees 12V (approx every 400km) it won't know any different. That is why you need to either a) wire via a switch to restore the connection (put foot on brake, CEL goes out, open switch again), or b) wire to alernative 12V source that comes on during normal driving but won't interfere with you making use of the mod, ie the reverse lights.
The only restriction if following b) above is - you can't launch with full throttle in reverse, lol. I think we can live without that :)
You will need the exhaust done, it is extremely restrictive, especially the dump/cat pos. That will help spool the turbo.
Speaking of which, I may be trying out an anti-lag button for mine to help spool the turbo at stall. I will let you know how it goes. (This should work with the emanage too.)
O really!
Pin 44 is the neutral switch input to the ecu, perhaps that is a good feed to splice in to...
That could work, but I can't find any info as to what that signal is & CBB checking it myself.
The voltages from the switch to the TCM won't work (looked at those before).
Edited by Commsman
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
