  • 1 month later...
As im not one for cutting up factory wires and get plug in parts. It has come time to bite the bullet and do the brake cut mod. I am looking at doing it another way than what has been discussed previously. As my car has cruise control im looking at finding the wires associated with the on off switch on steering wheel cutting and terminating wire on the body side of ecu and connecting ecu wire to whichever cruise control wire becomes active when switch is turned on. If that does not work i have a switch i can solder in and run it to glove box
Just did it with a normal switch. On thinking about cruise control on off switch i would be limited to 30% throttle for the whole duration if i used the cruise control on a long drive may have been good for fuel consumption but i will never know
So have you done a test launch yet?
Watched the mighty car mods episode 12 of the double unicorn build. It touched base about the throttle restriction due to the atessa system in the wc's. I wonder if it's the same for us as we use that system? It was along the lines of g sensor and voltage sending info to the atessa which would tell the ecu how much power to send to the tranny etc..
  • 1 month later...
There may be a big smile on your face. There definitely was on mine. Takes a while to stall up but it does happen.
Till about 3 weeks ago I didn't bother stalling up for more than 1-2 seconds , have been and still am very happy with general pedal response coming of the brakes. However bout 3 weeks ago I was waiting at a very tricky roundabout and stalled up for longer with foot flat ...... damn!! the grin I had! back end lost traction front scrambled for grip and the darn thing shot off like never before.
Car is stock except constant high boost, brake mod and trans cooler. This of course has resulted in a special kitty being formed for serious mods to happen. It is (to me anyway) exceptional how well these things get off the line.
Yep well worth the back cramps leaning in to the firewall, cutting and connecting the wires.
It's surprising how lazy Nissan tuned this car given the weight of the thing.
At least they gave it decent factory boost.
Even my wife loves it more now after she drove it through the forests of Durras lakes with the brake cut switched off.
Good little spot here for a switch, in the passenger side utility compartment.
Towards the back of the compartment , there's plenty of clearance behind for the mech.
Very easy piece of trim to remove, 2 screws then jiggle out.
Better than glovebox I think , less chance of getting broken.
I think my tyres are wearing out quicker all a sudden ;)
  • 11 months later...
Dragging an old topic up.
FYI, I have an AR-X that is 100% standard and I can get it to stall up on the brake to 3200rpm no problems, to the point that the rears start to spin. To my knowledge the mod hasn't been done as there are no CEL codes.
Not too sure on how much boost its making but it leaves hard off the brake with no hesitation.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
