Always hard to make up a decent plate.
Most of the obvious ones will be gone regarless of what state your in so unless you have a lot of money.
There are these
http://www.ebay.com.au/itm/VIC-MON5TA-personalised-plates-suited-V8-HSV-GTR-Evo-Turbo-Truck-Jeep-/230777720808?pt=AU_Car_Parts_Accessories&hash=item35bb6c8fe8
There are these
http://www.ebay.com....=item35bb6c8fe8
just had a look at a few.
42K 'buy it now' for plates DA WOG.
WTF???
My first step was to decide what message I wanted my plates to convey, then how to fit that into a standard format..
*It's a real GTR
*It's an R32
*V-spec ii
I ended up with ZLA32V, which I am pretty happy with.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
