That's just how long you gotta wait mate, to be honest I'd be very very very surprised if Sean or Andy know who I am before I rock up with my car and they've both tuned it many times. Got nothing to do with you not having had your car tuned there before.
As for how long it takes, generally if it's JUST a tune and it all goes according to plan then it's done by about 3-4pm if you drop it off first thing in the morning. But there's also a chance you don't get it back that day, it depends how they go with the other cars they have booked in. And if you're having other work done, ie. turbo install + tune or something like that then forget about getting it back on the same day, that's usually between 2-3 days.
In short: plan to be without the car for a few days, if you get it back sooner then that's a bonus.
Edited by Hanaldo
Yep, gonna be my wheel nut bitch again Brendah?! Might let u take the big girl out for a lap or 2 if ya good so bring you helmet. Will be running the street wheel/tyre set-up tomorrow, so there'll be no lap times broken :down: Too lazy to change em over for a half day track day.... and hung over.
Bringing the HQ out for a few laps now you have your new shockies n brakes sorted?
Looking fwd to it.
  • 2 months later...
  • 2 months later...
  • 2 months later...
Righto guys and girls!
Now that I'm finally back in action with the blue monster, my first track day will be the 14th June.
My old man is also planning on having the GT-R back out with his repaired front end and new oil cooler so it should be a very good show of RB noise and father - son banter if nothing else ;-)
Keep in touch on here in the mean time gang and let me know if you can make it out.
Usual deal: 9AM - 5PM, full length clothing, closed shoes, good helmet etc All details are on www.wascc.com.au
Hoping to encourage some new comers this year, so let's keep communicating and encouraging each other on here and how ever else we can.
Cheers,
Bren
Wes that's a bumber mate! Wish I could be at the one before as well but I'll be working away. We should catch up this break if you're free mate.
That's great to hear Bryce! Look forward to seeing you's out there. Keep an eye out for us Blake boys and the bay side blue R34, and come say hello ;-)
I'm pumped already. I've decided I'm just going to run my current old R888's totally into the ground because it will be my first track time with the new blue monster so no point in trying to brake lap records so to speak - I just want to learn to control the power and get comfortable with the new set up (hopefully without heading off the track and wrecking the new paint/body kit) haha
Talk soon lads
Brendan
Went on my first track day last night in prep for yours Bren :)
Only did short track as it was raining during the day.
Got a Flat 60 seconds exact for the short track, not sure if that's good or not, but it was my first time ever on a track racing :)
Really good fun!!
Car went great!! No Issues!
Hey Bryce. I've been in touch with the boys and it looks like everyone I've been talking to is going to make it - despite the threat of a few possible scattered light showers. Are you and your mate still looking good to be there this Friday? There's 5 confirmed hypo skylines going to be there so far - all big hp and nice set ups too, which will be awesome for the camera footage.
Cheers
Bren
Hay bren, me and my mate will be there in our r33's, can't wait :) hopefully good weather comes our way to
Cheers Bryce
Hay bren, yeah mate I'm still going, mate has dropped out in the other r33 , so that's a bummer, coz his car would of been added on the hypo skyline list :) but couple of other mates are coming. Can't wait to hear all the rb's on full noise tomorrow, sounds like it's going to be a awesome day. cheers bryce
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
