Okay about 2 months ago I had got the dodgy exhaust system one of the previous owners put on ripped off and redone.
2.5inch, high flow cat, 1 resonator. But I left the cannon on it because I couldn't afford anything more at the time...
Obviously the thing to too f**king loud, I didn't really care and got used to it. Clearly the cops didn't.
Today I got pulled over, yada yada, $88 fine and EPA will send you a letter in a month.
The plan now is to rip the cannon off and throw on a twin tip muffler. The question is, will this pass through EPA? (Provided it is under 90db).
Thanks in advanced.
EPA emissions? that is the letter in the mail one? they dont look for noise just the emissions the car emits defect for exhaust noise and having to go get a check to make sure its 90db is the one you should hope it is? should be easy to pass if it dosent you need another muffler or resnator in it
90db isnt very loud at all, one resonator and a twin tip muffler is wat i run and i dont think mine would be under 90.
best bet would have it tested somewhere... judt dont know were ud dtsrt
  • 3 weeks later...
"... the vehicle bearing Registration Number XXXXXX is excessively noisy and therefore likely to be exceeding the legal noise levels for the vehicle..."
"The noise test and anti-tampering inspection must be undertaken by an EPA approved Mechanic by the compliance due date which is Wednesday, 23 May 2012"
"- the engine test speed for your vehicle is 4800 rpm and the legal noise level for your vehicle is 90 dB(A)."
Again, I have a stock standard RB25DE with a K&N high flow panel filter, and a 2.5" exhaust system with a high-flow cat and 1 resonator + cannon (Will replace shitty cannon with twin tip muffler, hoping for less than 90 dB), stock extractors.
Will that pass the test? I'm just curious about the 'anti-tampering' part of it. Is a high-flow cat considered to be 'tampered' with?
Thanks.
would put money on you not passing with your current set up, my guess would be 97-98 decibels.
if you could get away with the plate that would work (again asking as they didn't see it. perhaps place behind the cat flange with 5 1cm holes drilled in it and only make the plate 1-2 mm thick)
*not sure on how many holes lol
Been there done that when I was on my Ps lol..
Best thing to do is borrow a standard exhaust from someone on the forums (heck im sure someone will lend you it for a day in exchange for a case of beers).
- Take off current loud exhaust
- Put on standard exhaust
- Go to EPA
- Pass inspection
- Put back old exhaust on and return borrowed exhaust
Your looking at about $50 for a case (depending on what your buddy prefers :P), $60 from memory to take the test and the $20 or odd you will be spending driving to pick up the exhaust and drop it back off.. Still adds up alot cheaper than paying a couple hundred and getting a whole new exhaust fabricated
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
