Hi guys. Ok so a short run down on my situation.
Recently just put an RB25DET motor from a Series 1 Automatic R33 into my manual R32 GTS-t.
I drove the car that this RB25 came out of for around a week, NO ISSUES at all with the motor.
Got the loom made up by Sideshow Wiring (Jim) in Queensland.
Motor is standard, standard intercooler, turbo, no boost controller etc, 3.5" HKS catback exhaust, Blitz pod filter and splitfire coilpacks. Brand new spark plugs. Running the factory Auto R33 ecu.
Now my issues were that it was running really rich (like 200kms to a tank and blowing stupid flames), and had a fairly large and noticeable dead/flat spot between 3500-6500rpm (doesn't really feel/sound like it's misfiring though).
It would also want to stall if I approach the lights with the clutch in, but would get down to about 100rpm and pick back up again. Would only occasionally do this..
ALSO, if the motor was under fair load (say going up a hill) at around 3000rpm, the motor will cut out and quickly come back again.
So I thought, I'll replace one thing at a time and see how I can fix it.
New spark plugs regapped to 0.8mm, have tried three AFM's, two sets of splitfire coilpacks, o2 sensor, Bosch 040 fuel pump and finally an RB20 wastegate.
Nothing fixed any of the issues. So I thought I'll hook up the consult cable and look to see if there's any fault codes. Sure enough one came up, number 54 - A/T control. Was sort of happy, thought that the auto ecu may have been going into limp mode or something similar.
Managed to find a manual R33 ECU and plugged it in - ALL PROBLEMS VANISHED!
Or so I thought. The car was wanting to still stall when I approached the lights.. I found a bit of a leak in the pipe which leads off the blow off valve, replaced this and what do you know the stalling issue is fixed too!!
So I take the car out of the garage thinking I have fixed all issues, and I give the car a good rev onto an onramp... Nope, all problems appeared again. Running stupidly rich, really distinct flat spot (still making around 0.6bar boost) and a new problem also - very slight misfire when I lift the throttle off, can easily tell it's running on 5 cylinders for that quick moment.
I checked the faults with the consult cable and nothing has come up.
I really don't know what else to check/change, I've done as much as I can without spending obviously a rediculous amount of money.
I don't have the money to take it anywhere, nor get a PFC + tune etc.
Does anyone have any ideas as to what this could be? Surely it has to be something stupidly simple...
Any input would be greatly appreciated.
Regards, Brent.
That was the number one thing I said I'm not doing. The car is standard, it shouldn't need a tune or aftermarket ecu.
The car WAS running 100% fine for about 20 minutes after I replaced the ecu with a manual one. And then got back into old habits, I guess because something is telling the ecu it has to run that way...
Well if you have a
Manual ecu with correct wiring loom, you say you have coil packs, airflow meter, I would check cat converter I'll have a better think about it and get back to you but I spose your right you probably
Don't need a tune im just saying of u had a power fc and a retune your issues would probably
Be fixed or atleast be more
Viable whilst tuning very hard to
Diagnose over the Internet with the provided info.
Well he has only replaced the ecu so as I
Said its hard to diagnose over the net. I doubt he has wired it incorrectly from the sounds of things I would say best bet a component is faulty once checked everything than I would check ecu .
True. I forgot to mention that I'm running a de-cat pipe and my timing is set perfectly at 15 degrees. Could the cas still be faulty? It's one thing I haven't replaced as of yet... A mate today also suggested could be an earthing issue? Where the hell would I start to determine whether it's an earth issue?
i would be checking all areas of wiring that YOU have physically tampered with make sure the pinouts on the ecu have a proper earth. It may be a process if your not confident, if this where me i would spend a day looking through the faults than if nothing, take it to a mechanic.
It just occurred to me, do you have any sort of speed signal being sent to the ecu? That may be causing part of the problem if it isn't right. The ecu factors it in, as it does with the neutral switch. So if the ecu is getting the wrong signals then it will be using the wrong maps
  • 1 year later...
Yes this did get fixed. It ended up being an issue with the wiring loom conversion. I can't remember exactly what the problem was, may have been something to do with the TPS from memory.
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
