  • Replies 83
haha @ Dave... f**kin crack up
anyway if you were goin to go single (in particluar) borg warner, you cuold probably nearly get away with a 300sx 83/75 with a smaller .91 housing, if not they recomend the larger rear housing which would definatly get you to 500 on E85.
Ive heard precisions are good, cant say first hand though
The BW are awesome bang for buck.. and sounds great :D
That was the engine dyno results, no airbox/intake piping, drivetrain etc.
Would be back under 500rwkw you'd think once in the car. Hard to say as no results got posted after that far as i know (be awesome if they were handy to see once incar).
oh ok, doesn't say engine or chassis dyno so I couldn't tell, though he has posted some where 533wkw in the 33 with -10s.
ok, yeah haven't seen it
poor op,if i'm correct he asked how to make the best of this set, NOT should he run GT-RSs or not and instead of people helping him out he gets hammered with GT-RSs are crap or go single, people should be ashamed
I will say this big duration low lift cams are not the way to go, these turbos need backpressure between the turbo and engine, so the less overlap the better, and as little as possible out side the turbo, higher static comp ratio will help to by loading up motor better, I am also cleaning/smothing the exhaust ports aswell as a minimium, 3" dump pipes to a 4" exhaust would also be a minimium after that remember how they went on so it will be easier to change them to something not garret.
I am still going to use them as it is a street car and the steep ramp rate will make it feel fast for a mates :P
lol thanks bro
op is sweet. ive been sitting here with a bag of popcorn reading this shit thinking to myself when did all these nissansilvia members sign up to sau.
the twin vs single arguement is going to go on for ever similar to that of the holden vs ford etc arguement, there will never be a winner or loser just a bunch of dream boats looking like f**kwits because they think that god himself built there engines and there turbos are any different from anyone elses.
i dont give a f**k about the twin v single arguement - i clearly said it myself if rules in victoria werent so tight and cops didnt think they were judge dred i would 100% get a large single like a gt42r or something.
im not a teenager going for f**k off power to impress my mates or little broad minded persons on the pavement. ive had 3 gtrs now and a multitude of (some very highly modified) imported and european cars so i know exactly what i want out of the car for ME!!!
i asked 2 questions in my first post (still not answered on here but have recieved some insigtful pms from some members)
what head work do you recomend for a high powered rb26/30 (in comparison to what my engine builder has recomended)
what are ppls opinions on gt2871r
now my first question has been answered by other avenues so disregard it.
my second question regarding turbos has led me to believe that alot of ppl dont like 2871rs for what ever reason.
i understand that engine work, head work, cam selection etc needs to be carefully evaluated to make them work to there full potential (which on paper looks acceptable)
if people want to post about the benefits of going single turbo on my car you are simply wasting your time and making me have to read more posts so keep it to your self.
i have been in an r32 gtr with a pretty built engine (standard capacity) with 2871s making 400 kw and it was quite a good little package (5000rpm full boost) i feel that with my 30 block i should be taking 800rpm off that and get it to the low 4000rpm range which is where the gtx3582r would have been hitting full boost (have seen actual results on a car on a dyno similar engine with the same gtx3582r that i had with the tial housing)
now please continue your pointless never ending arguement and actually give me the responses im chasing
peace
We have given our answers, you engine builder needs to do it to suit
or would you like us to say
you need to take out exactly .8432356 mm of matierial from each of the intake ports
to flow exacly xx CFM at 28" HG
we cant do that
every engine is different
we cant do that
This is what i was saying. get a builder that 'knows' how to make them work if you want to use GT-RS'
The correct cam selection, port job, secret squirrell stuff, that usually isnt revealed, to make things work.
The guys with years of experience building and tuning similar/different combos will make them work.
oh and $$$,
If your builder hasnt had the experience to make them work, you will just end up with a not so good result with them, where as the -5 would of achieved a similar feat.
we can tell you to put 290 degree cams in it, but if they dont match the specific port/head work. its pointless.
lol
nah dude
gtx2867r twins
tial housings
internal gates
looking into e85 as well.
it will look stock enough from the top (all the piping will be black etc)
should make mid 400s and keep me happy enough.
67 mm versions.
Considering the result Gav made with the 63 mm versions (500 rwkw at 26 psi), this will be one wild ride!
Tial housing? Whats different with them and why the decision not to stick with the housing's that come with the HKS and Garrett versions of the large low mounts?
I like the how the tials look lol
nah from a bitta research ive found that the tial housings are .64 and the standard rear housing is .84 (i think) so will bring them on better!
However!
Tial rears are v band which means custom pipipng, manifolds etc so adds to the price alot and i dont think it will look standard enough!
Speaking with my engine builder he rkns that the extra price will be alot!
-5s will make 400kw +
Cost for -5's is like 2500 a pair
The gtx will make considerably more power (apparently) but cost is (from us website)
1450 each turbine housing
then add rear housing of choice
actuator of choice
actuator bracket
optional polished compressor housing
v bands
then u still need manifolds and custom piping as well!
Would be cheaper to buy hks 2530's
However!
actuator of choice
actuator bracket
v bands
Well look, this seems like you haven't done much research because for a start you've got the rear housing wrong.
Also let's face it, you've asked for 450-500awkw. That's MASSIVE numbers. Which equates to MASSIVE cost, but you're concerned about the cost difference between -5's/GTX5's/2530's? Be more concerned about the huge dollar head you will need, the OSGiken gearbox, the big multiplate clutch, the expensive FMIC, the big fuel system etc. the difference in turbo purchase price is chump change compared to the rest of that stuff.
Just put normal -5's on there, wind up the boost and be happy. If you must have a bigger number to satisfy whatever it is that made you want those numbers in the first place, get the 60mm versions of the GTX-5's and you'll make mid 4's without too much drama. 63mm's will have more lag, but will add a bit more power of course. Forget 67mm's, it's way too much for your power goal.
Don't take any of that as an attack or as being rude. You want honest advice, there it is. That's all I have to say on this topic
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
