  • Replies 89
Love this pic Alex!
Sorry I missed it - looks like you all had fun.
That's my favorite pic of my gtr, my mates gtr and the awesome r35 gtr !!
Thanks guys, the Mrs was snapping away inbetween bumps! What happened before that was slightly butt clenching up the hill with the coaster bus. Lets just say performance gap between R32 GTR and R35 was displayed in front of me. Provided the lulz looking back on it.
Go another of the R35 on a seemingly empty road- one of my favs.
Me neither.
By the way, it was nice to meet you on the side of the road in the middle of nowhere Brodie. :)
Well run cruise guys, as usual. It's always fun to tag along with the Skyline Club.
haha you 2 man
Had a great time yesterday, meet a few more stagea owners and good to see some familiar faces again :)
here are a few pic's i took https://www.facebook.com/media/set/?set=a.293216754091850.69150.192043784209148&type=1&l=52dcba9518
Nice shots there Alex. Are those through the windscreen? Suprisingly no glare if they are. Kudos to your Mrs!
Yeah they are Eric, I'll pass it on. And just a old Canon point and shoot- bout $120 worth! Goes to show sometimes it doesn't matter what you got- its what in the pic that counts! :P
Awesome Day, one of the best cruises I have been on.
I would have loaded more pics but I hit my upload limit for the month. Link is below:
http://www.flickr.co...s/77653397@N06/
heh, thanks for the photos.. I didn't go home .. i just kept driving up through the vineyards :cheers:
Great cruise! First time on putty rd, was loving sitting behind your car, it looked awesome when it took off! Good to see a 35 being driven as nissan intended!
Thanks for the Photos!
The look great and yes my engine before had the oil restrictor blocked by some junk and seized oil to the head.
Was an awesome day all round.. Keen to see some more pics, I was going to get some at the end point but by the time I had finished lunch everyone was pretty much taking off... The only pics i got was of mine just after the bike crash waiting everyone to come back through ha..
I only took a few pics as well. I hope some of you also took the opportunity to take some pictures of your pride & joy while in the Hunter too. Lots of great back drop scenery.
Love the first one 'the hot chick' need to facestalk and find her :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
