I just got a clutch from KB clutches in Sydney.
He was a really nice bloke that asked everything to do with the car and the power/rpm/use
Managed to pick something up for $410 including postage to ACT
Only time will tell if it holds up or not.
But I currently am pushing around 240-250rwkw
I know this is an old thread but i did a quick search and didnt find what i was looking for, what is the Exedy cushioned Button 34GTT clutch rated too power wise? I think it was 330rwkw from memory, but if somebody has a better indication please let me know as i will probably let the guys know before they tune it ;)
I'm hoping my cushioned button holds up, should do for a while as it hasnt done a huge amount of work..... Just not sure of what its rated too?
Next clutch for mine will be the JB i think as i was told they are good to drive :D
Softer than stock pedal, no shudder, holds massive power.
Hmmmm mine definately shudders which is sent down my drive train to my diff. Subsequently, the backlash in the diff is sloppy as and all I hear is loud thuds if you sit on the clutch longer than a second. Clutch has done about 3-4000km's since new. Flywheel was machined by JB aswell. I thought it might be just a wearing in issue, but it would seem its not!
Also, how does yours take up/grip? I've found mine goes from OFF to ON in a VERY small range of movement...
Edited by R32Abuser
That can't be right surely?
It's a single plate clutch. Can get the same thing from NPC with brand new parts instead of the JB second hand ones. NPC are only about $750-$800
Ive seen people quote like $1300 odd on here.
If it was 2k then I would not even consider him and just go straight for a nismo coppermix! or if you dont have the coin then get a NPC clutch.
The shuddering might be caused by the cracks in the second hand pressure plate
got mine for about $1000
4100 lbs of clamping force. Plenty of clamp for my application - if anything its WAYYYYY overkill considering its a street car.
Elite/Daniel, surely JB would have seen this? This has happened from day one, and he said that it would initially shudder but would come good after 1000km's.
They go for about $1200 depends on what you get. The shudder could be from contamination, oil and crap getting on the flywheel makes it glaze, hence shudder.
Yeh my clutch has a small friction point, 100kms of driving and you get used to it.
Just for reference, the pricing on the GTT was quite a lot more than a GTST as they are the pull time clutch etc..... My Exedy was around $1300 at trade price at the time i got it (They have probably come down a lot now) but the 34 clutches were quite expensive..... Just like EVERYTHING else on the damn things that is slightly different to the other models :glare:
If your poor ten obviously your going to go for the cheapest option
Well surprisingly the 33gtr has the same clutch as you *gasp*!
Npc sprung button clutch capable of supporting up to 650hp
$750.
/thread
$750.
/thread
Wow, i said "pull time" that sounds pretty dodgy :P
Ill definitely be looking at other options when it comes to the next clutch choice... SO FAR the cushioned button has been good, so hopefully it holds up.
To the OP, shop around as it seems there is plenty of options around ;)
Hey guys,
Sorry been so busy with work and getting my car sorted etc.
I ended up going the NPC Heavy duty Organic clutch, Rated to around 300rwkw this is plenty for what im going to use it for.
i got it all installed and parts (Inc Flywheel machining) And my coils changed while he was there, 4L of Redline lightweight shockproof for a grand total of $1360 (Inc clutch, labor, oils, maching of flywheel) Not bad if you ask me, im pretty happy with how i did, Now for fuel pump on the weekend, and then off to powertune on monday!
POWAHHHHHHHHHH!
Thanks to everyone who dropped their 2 cents worth, it was worth alot more to me :D
<3 SAU
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
