I reckon the Exedy will have a short lifespan as i think they are only rated to 330rwkw so i am pretty keen to see what all the NPC hype is about, they sure sound good and are HEAPS cheaper than what i paid for the damn Exedy!
Everything used in the NPC clutch is Exedy parts.
Doug modifies them to suit the application though. Nissan Patrol hub, 250mm plate, 350Z 250mm pressure plate etc
Oh... Well that is interesting! I should contact him and see what he says about mine and wether i should start thinking about it now or just let the other one go and see what happens....
If im looking at over 300 in the next few years does it seem worth me getting the 10" sprung carbotic over the 10" organic? Or would that be overkill for me? its a daily with 2-5 track and drag days a year. From what i have read the organic is rated to a bit over 300, just worried if i go for 330 next year that the clutch wont take it too well.
Got in touch with NPC
Hi Johnny,
I would recommend our 10 inch heavy duty carbotic button clutch kit.
$755 inc gst for the kit.
To give you some idea the clutch has 1700kg of clamp load & will hold 400rwkw.
I would be lying if I could tell you how long it will last. I would expect allot longer than sports organic.
Thanks,
Doug
Hi Johnny,
Thanks,
Doug
yeah thats spot on.. same clutch i run. i dont daily my track car but i did do 300 kms of street driving in tasmania in it with no probs haha
That's bullshit he's lying.
They definitely hold 450rwkw for a long time, 2 step limiter launches, nitrous enriched 2nd gear multiple clutch kicks, power skids and seasons of track work.
I don't know why he would mislead you like that. I told Doug ages ago how f**king good they were
I have one of these. Street is no biggy but with the extreme cold weather in the morning it needs 5 minutes of nurse driving then it becomes fully streetable. Handles all wheel launches and anything else Ive thrown at it. Been in for 4000 km so its still early days.
Why? Shudder?
Yeah but I guess he is being slightly conservative.
After all if you give a dickhead an unbreakable object, my money is on the dickhead.
That is true.
As a matter of fact, a customer who is new to button clutches is more likely to kill it with kindness rather than abuse. Riding it too much is a killer.
I would ask Doug if he can make you a 6puk plate instead so its easier to drive and definitely go carbotic over ceramic. It's a little bitier but definitely handles the heat better
I don't really ride my clutches usually it's a on and off love affair with me :)
I'm just waiting on Doug to see if he can also get a gearbox front seal kit & stronger pivot bolt and it's on like Donkey Kong! If the clutch is too heavy, I will upgrade my slave to a Nismo item, like I've done in the past.
Doug builds clutches. Why not just go to Nissan for your seals and gasket?
The clutch pedal will most likely be lighter than your existing clutch. They are almost lighter than a standard HD. You won't need a pivot ball. Just lube it properly
Nissan spares are only open weekdays and unfortunately I work a boring desk job in the city. I might just go through Kudos and order it.
I've heard horror stories of stock pivots snapping with heavier clutches, on my previous R33 I went all anal and replaced the pivot, slave, seals etc.. lol
Tried searching on Amayama.com? Ive had a few good purchases from them..... Not always cheaper but a couple of items have been WAY cheaper and just as fast to get as Nissan were even from JP
It's on like Donkey Kong!
Just ordered it, now I need to clean the BBQ and buy a slab of beer to bribe a few mates to drop the box. I wish I still had access to a gearbox stand & hoist makes life so much easier :unsure:
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
