I'm sure a competent tuner can sort all that out quick smart, and I can guarantee no competent tuner will just hand out such information either, considering it will have taken years to work out.
The spirit of sharing information on forums to assist fellow enthusiasts...is no more?
'quick smart' and 'years to work out' are a tad of a contradiction don't you think... ;)
Tell you what, I'll start my own thread with my findings (HyperGear SS2 + E85)
Matt
Edited by BoostdR
  • Like 1
No its not a contradiction. It takes a lot of experience to become a good tuner. One of the skills of a good tuner is toe able to quickly pin point problems with a tune. Having said that a good tune still takes time because of the many variables in each case.
I have had a lot of information and valuable tips from members of this forum for which I am very grateful.
That's all well and good but you have taken my comment out of context.
Scotty was leveraging on my use of the word competent, I was leveraging on his contradiction.
It's all good. I'll sort it out and post up my setting when I do.
Let's not fill this thread with useless posts anymore.
