34's seem to make a ridiculous amount of noise with pods on anyway, mine howled at 40km/h when i had one on; ultimately i swapped it back.
I've noticed that people that are dead serious about getting more air do use a pod; but they extend the hose and bring it right round to the front of the car infront of the radiator. I'd consider doing this; but i'm not sure it's possible without drilling big holes near your headlight and can't find anything relating to us anyway. I would wonder about effect of the filter getting wet out the front too.
https://www.sau.com.au/forums/topic/399180-r34-pod-filter/#findComment-6340161
Shattered I wasted money on one... Wow it Seems to be an urban myth that people have taken to heart... I've read
tweak guides that promise 10-15 kw boosts and both my uncles that race cars were talking what a difference they make.
Unless being out in the wind under real conditions can somehow make a difference to the test; i would say that myth video
makes 90% of us with modified cars idiots.
At least; it was good to know the stock box does not restrict in any way. Perhaps those asians in white coats
that designed the things sort of knew what they were doing? :unsure:
https://www.sau.com.au/forums/topic/399180-r34-pod-filter/#findComment-6341902
The airboxes are a good design, you see plenty of powerful cars running stock airboxes..... The only reason i ran a pod and custom airbox was due to the way the piping was routed but i have made it look as stock as possible....
For performance advantages there are better ways ;)
PLUS stock airboxes avoid potential defects too AND have the intake snorkal, but they fetch good coin if you sell them.....
On that note, i have a K&N pod off my 34 i can sell him cheap if he goes down that path, but probably better he doesnt!
https://www.sau.com.au/forums/topic/399180-r34-pod-filter/#findComment-6342687
Don't take it too bad, in the end it is just an air filter, it's not going to make or break your setup.
Yeah after watching it I was glad I only spent $50 on my pod
Rather then getting an apexi for $130
Still going to talk him into getting a highflow pannel filter.
I am sure they would help at higher power levels
The difference between a cheap pod and an 'expensive' pod isn't the power they make, it's the quality of the filter. As I mentioned above, the things are just air filters. You're not paying x amount for y amount of power. I've seen a few 3A Racing and some other cheap brands literally disintegrate under boost, and when you pull the pod off you can find little pieces of filter element in the intake pipe.
That said, I've seen the same thing happen to HKS pod filters, but they are a rubbish design anyway.
https://www.sau.com.au/forums/topic/399180-r34-pod-filter/#findComment-6343131
whats he want a pod for? induction noise?
Look at the car there testing it on, stock airboxes are restrictive if your trying to pushing past the factory pipe limits...there vids are pointless, especially the one about "Will BOV's make more power"...f**king retards lol..
https://www.sau.com.au/forums/topic/399180-r34-pod-filter/#findComment-6343390
But see again its not all about more power, having denser air would also result in less pinging which means its healthier for the engine, Ive noticed my car used to get abit of knock in 2nd gear with just the pod, once I made a enclosure and got a pipe from the bumper to the box theres not as much noticable ping.
https://www.sau.com.au/forums/topic/399180-r34-pod-filter/#findComment-6344023
Your car must be tuned right on the edge then, surely. I mean the air flow meter is a heat element, it takes temperature into account when it calculates air density, so any heat soak you are getting from the pod shouldn't cause knock, it will just mean less power.
https://www.sau.com.au/forums/topic/399180-r34-pod-filter/#findComment-6344082
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
