Hey guys,
noobie to the boards but have had this car for a while.
Hoping that I can get some assistance because im getting a little overwhelmed!
The car:
Stock R33 GTS-T S1 - Automatic. not even a pod filter or FMIC.
The symptoms:
had the battery disconnected for a few days, plugged it back in started the car. Idles beautifully for a while 2-3 seconds then goes rough.
If I put my foot down it has a huge rev drop and will often stall. If it doesn't stall it will very slowly rev out and has no power at all. If it stalls, the car will turn over but not start. If i reset the ECU (battery fof and pump the brake) then it will start again, but with the same issues.
I get maybe 160kms per tank.
The ECU throws out no error codes. (ECU was checked before the initial battery disconnection)
also seems to be some potent fumes coming from the exhaust.
What I've done so far:
replaced AFM
replaced 1.1mm gapped plugs with 0.8 platinums
replaced coil packs with Splitfires (was getting massive arcing issues and these work amazingly!)
replaced fuel filter
ensured all intake hoses are sealed nicely
I'm thinking that this issue could largly be attributed to by the O2 sensor as I'm pretty sure it's never been changed. just waiting for the socket to arrive to change it over.
Has anyone else got any ideas on where else I should be looking? injectors? fuel pump? CAS?
any assistance will be greatly appreciated!
-Adam
if you want to rule out the o2 sensor then just unplug it. in all honesty, the o2 sensor does bugger all when it comes to issues like this. it sounds more like you have a fuel issue. as jonboy said, look for vaccum leaks as that will make it run mega rich. i bet that if you pull out a sparkplug it will show signs of running super rich
anything I should be looking for specifically for vaccum leaks? just took off most of the intake and put it back together and made sure all the hose clamps were nice and tight. can't hear any obvious hissing either.
should have mentioned, already tried unplugging the O2 sensor. no difference at all. also should have mentioned that i did the O2 ECU test and it's running rich.
most likely it is running rich because of the issue you have, not because of the o2 sensor. the issue is probably causing the car to run too rich for the ecu to use the o2 sensor to lean it out
If it is stock and you have new Splitfires, then reset the plug gaps out to 1.1mm (certainly don't close them down to less than 1mm). Are you sure you have the right heat range plugs - RB25s use a 5, eg BKR5E.
Have you cleaned the injectors - not just run injector cleaner, but remove and sonic clean?
Clean air filter?
Check ignition timing.
think I may have found the problem.......
ran it for about 5 minutes. checked oil cap. thin layer of cream coloured shiz. also running low on compression for cyclinders 1 & 2. looks like fun times ahead! :(
Just hope it's only the gasket and not the head.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
