Are you a PC or MAC User?
81 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 349
Posted Images
Hey guys, just looking for any info on an ultrabook i want to get for my little sisters birthday
I dont really know too much about these things, i just know that windows 8 is a must
is this any good?
http://www.jbhifi.com.au/computers/asus/11-inch-touch-screen-ultrabook-sku-90634/
Specs wise, it looks ok, just interested if anybody has any more opinions
is this any good?
Probably good for the price but under powered.
Rather than swap in a SSD, maybe spend a little more and get one with a preinstalled SSD and faster processor?
Get someone to chip in and get this? http://www.jbhifi.com.au/computers/asus/13-inch-ultrabook-sku-90637/
Get someone to chip in and get this? http://www.jbhifi.co...book-sku-90637/
i saw that one too, but 800 for a girl to do junior highschool work on, and surf facebook, seemed a touch much
i've played with a few of these at lunch and it was pretty terrific. But ill be damned if i listen to the people that work at JB
you imaginary internet people are always far more helpful
if she is only junior HS FB then a 60gb SSD would be plenty
i just bought a dell 10" netbook for my daughter took the 250gb hdd out and chucked in a SSD and upped the ram from 1gb to 2gb and it fly's now might see if i can chuck windows 8 on it :D
the one thing im chasing more than anything is, that if im going to force her to learn windows 8, i do want it to be touchscreen
its my understanding that the whole OS is developed around the idea and that if its not a touchscreen, she'll be busting my parents arse for a tablet in a few months
if it works out as well as i hope, i might copy the setup for my place too
My hipsterspec white Mac wireless keyboard is filthy.
How do I clean?
Since when are you asking other people for advice on cleaning? You are the go to man for advice in that area. I also consider you an expert in hair styling, rainbow painting and unicorn riding.
I think the 131166 is a national freecall whereas 94811111 is a Sydney local call... other areas had there own numbers too. We used to have ads with 94811111 jingle. Just looked on Youtube, nostalgiaed but couldn't find any.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
