I know, but it's not the same when I don't get to visit her! :)
Every man has his price! :)
At least the Nur has the appropriate 19" LMGT4s back on instead of 20" rims.
If in the Blue Mtns you can drive mine if you're over 30 lol
Coil packs gone, and lenses when I get around to dropping them off.
Turbos still available.
I have a pair of stock R33 GTR turbos off my blue thing sitting in the shed that came off at about 70k when the HKS units went in. No idea what they are worth, but PM me an offer if interested.
Also have a pair of R33 GTR Nismo clear side indicator lens thingies in good nick that can be yours for a measly $30, and a set of R33 GTR Yellowjacket coil packs that have done less than 1000K's work for $200. Think those will also fit some Stageas and S1 R33 GTS-T's from memory, but you would need to check. Again, do the PM thing if keen.
Cheers,
JD
This is true, he's not a collector so never planned to keep it.
Haha sorry, those 20s were perfection on that car in my eyes! Not really a fan of LMGT4s. But hey wheel choice is a personal thing!
And thankyou but I have my own little toy in the garage! I just like viewing rights on others occasionally :D
Hey guys just selling some stuff to clean up the garage contact me on 0410717935 if you want something or pm me on sau. Message me
For photos
So I got a set of low king springs $150
A series one front bumper great condition $100
A series 2 kr4 silver bonnet $150
A 52mm 3 row alluminum radiator eBay job $80
A rb25det block, intake manifold "taking offers"
A cam cover $10 And a exhaust manifold heat shild $10
A fusion wiring kit $15 and 2 x gear knobs $10 each
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
