Fj 20 engine and numerous parts for sale
Engine is in pieces at the moment
Would like to sell whole but will separate
Standard t3
Blow off valve
Standard injectors $50.00 each
550cc injectors $85.00 each no need to drill out injector
Plenum $100
Sump $ 100
Head $ 250
Wisco pistons $50 each
Standard internals
Will sell whole engine $ 500
Will not ship must be picked
For Sale:
Rb26 engine out of r32. 107xxx kms.
new genuine water/oil pumps replaced less than 1500kms ago
new dayco timing kit at same time.
standard everything except nitto throttle body gaskets
comes with all inlet gear except injectors.
Nothing on the exhaust side
will come with sump (no diff in it though)
will come with clutch ( its pretty shagged though)
Lifters are very noisy when motor is cold, goes away once warm. You are welcome to inspect/comp test. motor is still in car and running until saturday.
Pm me
Fs hypergear Atr43g .63 turbo kit comes with turbo high mount manifold 3" exhaust from turbo to cat braided lines and turbo smart external wasit gate $800
I might want it.
For rb 25? 20?
How much use has it had?
Any pics?
Hi guys I'm selling my car audio gear including custom boot set up for an r33 including custom box 12inch clarion sub and clarion amp plus to jl audio splits all top of the line gear if your interested please msg me and i can send pics and other details. 0457133010 cheers
Stripping S2 R33 Parts
Prices are negotiable.
GTST wing $150
ECU $150
Wiring loom $150
Side skirts $150
Rear bar $100
CD player surround $100
Double din CD/DVD player (alpine) $400
Shifter surround $50
Centre console $100
Front seats (minor tear on bolster) $150
Rear seats $100
Boot hatch $100
Tail lights $200
Skyline rear centre garnish $100
Door windows $150 each
Window regs $150 each
Aftermarket cat back exhaust $300
Coilovers $500
Engine $1000 (170,000 kms complete no turbo or bolt ons)
Diff $200
Half shafts $100 each
Rear adjustable camber arms $150
19" rims $1000 with brand new tyres
Turbosmart boost tee $50
Turbosmart boost guage $50
Aftermarket adjustable tie rod ends $100
Stock clutch $100
Flywheel $100
Passenger front guard (perfect condition) $100
Tail shaft $150
Starter motor $150
Alternator $100
Front and rear Brakes $400
Brake rotors $200
Hubs $300
(SOLD) - Coil packs $150
(D/S SOLD) - Rear Lower control arms $60 each
Rear cradle $100
Front lower control arms $70 each
Seat belts x 4 $150
Door cards $100 each
Window switch elects $100 (drivers side) $75 (passenger side)
Window switch surrounds $100 each
Side mirrors $100 each
Steering surround $50
AC control unit $100
Window wipers $40 each
Fuel flap $75
Fuel cap $20
Bonnet latch $75
Boot latch $50
Power steering reservoir $150
(SOLD) - TPS $50
Top AC vents $20 each
Passenger side headlight $150
NO FRONT BAR
NO INTERCOOLER or PIPING
NO TURBO
Still left over.
Also have a heap of mint condition I interior parts.
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
