G'day
R32 GTR full stainless exhaust including middle and rear muffler with cannon tip. 3 inch cat back fabricated by Hitech in Sydney. Used for about 500km before going bigger. Excellent condition. I think it will fit a Gtst also.
Replacement value over $1k. Asking $500 ono.
Open to reasonable offers via PM. No low balls please I'm not interested in giving it away.
Thanks
Due to an ordering error (which cost me $$!) i have a passenger side seat base for sale.
It is very solid and is made to meet fia regulations for fabricating a seat base.
Plenty of holes for mounting your brackets or seat directly to it.
Brand is Planted technology, rrp $140+ shipping from the US. Make an offer.
For R32
Edited by D.I.Y. Mik
Fs: cusco rear camber arms for r34 gtt, should also fit s15's. Never used. Looking for $400 neg.
Also have a hicas lock bar, never used $60 neg.
Still got my greedy oil cooler as well $450.post-88452-0-96023400-1374992706_thumb.jpgpost-88452-0-89269700-1374992758_thumb.jpg
For R32
Im too tall to use the bloody thing, with a helmet on my head touches the roof.
So BOTH sides for sale.
Another update
Stripping S2 R33 Parts
Prices are negotiable.
Can post or take a car load to Sydney. Located in a Canberra
GTST wing $100
(SOLD) - ECU $150
(SOLD) - Wiring loom $150
Side skirts $100
Rear bar $75
CD player surround $70
(SOLD) - Double din CD/DVD player (alpine) $400
(SOLD) - Shifter surround $40
Centre console $80
Front seats (minor tear on drivers bolster) $150
Rear seats $100
Boot hatch $80
Tail lights $150 (KR4 Silver)
Skyline rear centre garnish $50
Door windows $100 each
Window regs $100 each
Aftermarket cat back exhaust $300
RB20 Turbo (no shaft play about 140,000kms) $200
(SOLD) - G4 Racing Coilovers $400 ono
(SOLD) - Engine $600 (170,000 kms Long block, healthy and strong)
(SOLD) - Diff $200
(SOLD) - Half shafts $100 each
Rear adjustable camber arms $100
19" Maxis Super Hero rims $900 with brand new tyres
19" ROH Modena 3 Piece Rims $1600 with 80% front 50% rear
Turbosmart boost tee $40
Turbosmart boost guage $40
Aftermarket adjustable tie rod ends $70
Stock clutch and flywheel $120
Passenger front guard (perfect condition) $80
Tail shaft $120
Starter motor $100
Alternator $100
Front and rear Brake Calipers $350
Brake rotors x4 - $200
Hubs $300
(SOLD) - Coil packs $150
(D/S SOLD) - Rear Lower control arms $60 each
Rear cradle $50
Front lower control arms $70 each
Seat belts x 4 $150
(SOLD) - Drivers door cards $80
Passenger door card $80
(SOLD) - Drivers side window switch elects $100
Passenger side window switch elects $50
Window switch surrounds $80 each
Side mirrors $90 each
Steering surround $50
AC control unit $80
Window wipers $20 each
Fuel flap $60
Fuel cap $20
Bonnet latch $50
Boot latch $50
Power steering reservoir $150
(SOLD) - TPS $50
Top dash AC vents $20 each
Passenger side headlight $100
Power steering rack $100
CAS $100
VCT Solenoid $70
Turbo Lines $40
ABS Box $200
Manual Conversion (clutch master $80, clutch slave $80, clutch pedal $50, brake pedal $60) or kit for $225
Nissan Prince Foot well carpets x5 $300
Glove box with working latch $50
Fuel Pump $50
Fuel pump cradle $75
Antenna $75
Lock set (steering lock, door locks, boot lock with key) $200
Sway bars front and rear $50 each
Boot carpets and sides $100
Prob more that I have forgotten.
NO FRONT BAR
NO INTERCOOLER or PIPING
NO RB25 TURBO
NO GEARBOX
NO DRIVERS SIDE HEADLIGHT
do u have air con compresser and all the piping?
ARP Head Stud Kit Suit RB25DET, brand new only test fitted to block $150
Turbosmart Type 2 Blow Off Valve $50
RB30/VL Turbo Standard Setup, Original T3 turbo and Manifold, Dump Pipe Water and oil lines. Also have turbo plenum & runners also turbo brown top injectors all taken off running car,prefer not to seperate $800 taking offers
contact here or 0404429279you still have the arp head studs?
Seimens Deka 660cc injectors - $250
I bought these 2nd hand from these forums, but I never actually got around to putting them in. The first owner put about 4,000kms on them.
They come with the stock loom with the required plugs soldered on to the fuel rail spacers. So I can only presume that the loom would would only fit a S2 RB25DET NEO. But, not sure if the injectors themselves can be fitted to another loom?
Profec B spec II boost controller - unit only; $120
I thought it was broken, but I realised it wasn't fitted properly and it sat in the shed for awhile.
Happy to send pics, or for you to come around and have a look.
PM or mob:O432808254
Cheers, Karl
Edited by S T A R 3 3
Cheers, Karl
I might want to add that when I say 'unit only', I am pretty sure that it includes the valve and power unit too. But not the hoses, clamps and fittings etc.. but I will confirm tonight.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
