G'day
R32 GTR full stainless exhaust including middle and rear muffler with cannon tip. 3 inch cat back fabricated by Hitech in Sydney. Used for about 500km before going bigger. Excellent condition. I think it will fit a Gtst also.
Replacement value over $1k. Asking $500 ono.
Open to reasonable offers via PM. No low balls please I'm not interested in giving it away.
Thanks
Due to an ordering error (which cost me $$!) i have a passenger side seat base for sale.
It is very solid and is made to meet fia regulations for fabricating a seat base.
Plenty of holes for mounting your brackets or seat directly to it.
Brand is Planted technology, rrp $140+ shipping from the US. Make an offer.
For R32
Edited by D.I.Y. Mik
Fs: cusco rear camber arms for r34 gtt, should also fit s15's. Never used. Looking for $400 neg.
Also have a hicas lock bar, never used $60 neg.
Still got my greedy oil cooler as well $450.post-88452-0-96023400-1374992706_thumb.jpgpost-88452-0-89269700-1374992758_thumb.jpg
For R32
Im too tall to use the bloody thing, with a helmet on my head touches the roof.
So BOTH sides for sale.
Another update
Stripping S2 R33 Parts
Prices are negotiable.
Can post or take a car load to Sydney. Located in a Canberra
GTST wing $100
(SOLD) - ECU $150
(SOLD) - Wiring loom $150
Side skirts $100
Rear bar $75
CD player surround $70
(SOLD) - Double din CD/DVD player (alpine) $400
(SOLD) - Shifter surround $40
Centre console $80
Front seats (minor tear on drivers bolster) $150
Rear seats $100
Boot hatch $80
Tail lights $150 (KR4 Silver)
Skyline rear centre garnish $50
Door windows $100 each
Window regs $100 each
Aftermarket cat back exhaust $300
RB20 Turbo (no shaft play about 140,000kms) $200
(SOLD) - G4 Racing Coilovers $400 ono
(SOLD) - Engine $600 (170,000 kms Long block, healthy and strong)
(SOLD) - Diff $200
(SOLD) - Half shafts $100 each
Rear adjustable camber arms $100
19" Maxis Super Hero rims $900 with brand new tyres
19" ROH Modena 3 Piece Rims $1600 with 80% front 50% rear
Turbosmart boost tee $40
Turbosmart boost guage $40
Aftermarket adjustable tie rod ends $70
Stock clutch and flywheel $120
Passenger front guard (perfect condition) $80
Tail shaft $120
Starter motor $100
Alternator $100
Front and rear Brake Calipers $350
Brake rotors x4 - $200
Hubs $300
(SOLD) - Coil packs $150
(D/S SOLD) - Rear Lower control arms $60 each
Rear cradle $50
Front lower control arms $70 each
Seat belts x 4 $150
(SOLD) - Drivers door cards $80
Passenger door card $80
(SOLD) - Drivers side window switch elects $100
Passenger side window switch elects $50
Window switch surrounds $80 each
Side mirrors $90 each
Steering surround $50
AC control unit $80
Window wipers $20 each
Fuel flap $60
Fuel cap $20
Bonnet latch $50
Boot latch $50
Power steering reservoir $150
(SOLD) - TPS $50
Top dash AC vents $20 each
Passenger side headlight $100
Power steering rack $100
CAS $100
VCT Solenoid $70
Turbo Lines $40
ABS Box $200
Manual Conversion (clutch master $80, clutch slave $80, clutch pedal $50, brake pedal $60) or kit for $225
Nissan Prince Foot well carpets x5 $300
Glove box with working latch $50
Fuel Pump $50
Fuel pump cradle $75
Antenna $75
Lock set (steering lock, door locks, boot lock with key) $200
Sway bars front and rear $50 each
Boot carpets and sides $100
Prob more that I have forgotten.
NO FRONT BAR
NO INTERCOOLER or PIPING
NO RB25 TURBO
NO GEARBOX
NO DRIVERS SIDE HEADLIGHT
do u have air con compresser and all the piping?
ARP Head Stud Kit Suit RB25DET, brand new only test fitted to block $150
Turbosmart Type 2 Blow Off Valve $50
RB30/VL Turbo Standard Setup, Original T3 turbo and Manifold, Dump Pipe Water and oil lines. Also have turbo plenum & runners also turbo brown top injectors all taken off running car,prefer not to seperate $800 taking offers
contact here or 0404429279you still have the arp head studs?
Seimens Deka 660cc injectors - $250
I bought these 2nd hand from these forums, but I never actually got around to putting them in. The first owner put about 4,000kms on them.
They come with the stock loom with the required plugs soldered on to the fuel rail spacers. So I can only presume that the loom would would only fit a S2 RB25DET NEO. But, not sure if the injectors themselves can be fitted to another loom?
Profec B spec II boost controller - unit only; $120
I thought it was broken, but I realised it wasn't fitted properly and it sat in the shed for awhile.
Happy to send pics, or for you to come around and have a look.
PM or mob:O432808254
Cheers, Karl
Edited by S T A R 3 3
Cheers, Karl
I might want to add that when I say 'unit only', I am pretty sure that it includes the valve and power unit too. But not the hoses, clamps and fittings etc.. but I will confirm tonight.
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
