hi guys -
i have a R33 i am parting out with -
already missing is motor gear box tail shaft diff (diff might be for sale) calipers front and back and suspension and steering rack - aer gone - dash is bugged
good point body is straight - bonnet has some hail dints but good other then that (spray job wouldnt hurt) $200 ono
all seats front and back including rails are for sale - offers - all boot linings -
boot and rear wing standard R33 gtst - offers
fuse box in engin bay - no lid $20
has master cylinder and lines as well and handbrak just no calipers
good basic shell if anyone wants it $300
Edited by Reese69
hey guys ive still go a few things left over from when i stripped my 33.
hubs $250
intake manifold $150
control arms $50-70
passenger door missing window reg $100
clutch brake pedal plus master cylinders $200
cas $100
tail lights $130
most interior panels
jjr 3" stainless steel cat back exhaust $250
price up dates
plus some other stuff
intake manifold $50
both rear lower control arms $50
passenger door missing window reg $50
clutch brake pedal plus master cylinders $100
cas $50
tail lights $80
front and rear seats $180
jjr 3" stainless steel cat back exhaust $220
fuel pump $30
passenger side guard $50
stock cat back exhaust $150
stock shocks $150
turbo manifold $50
adjustable front tie rod ends $50
Edited by dd33
Just testing the waters locally for my 1989 R32 GTR
63k km on the dash (not sure if legit, but seemes clean enough)
Very Clean interior, stock GTR seats, dash perfect and uncracked (rare)
Drivers bride brix 1.5
New fully forged engine by chasers motorsports with receipts for most things from previous owner in ViC
<2000 km on the twin 2860-5 turbos
Haltech platnium pro ECU ~ safe tune
Apexi power intake pods
Gates timing belt
Adjustable cam gears
Freshly built head (you can see for yourself the fresh acid dip)
18x9.5 sparco racing wheels
Brand new excedy HDCB Clutch
Walbro 255lph fuel pump
Carbon fibre weathershields
+++ More but id have to go throgh my stacks of receipts!!
1 More month of ACT REGO!!
The setup will easily make well over 300kw with bigger injectors (I have ID1000 injectors ready to go in for extra)
looking for $14k ONO
or $12k ONO with stock ecu and different wheels
Or if you want everything done for the 100k km service it will be 13.5k + whatever your choice of mechanic charges
Why so cheap?
Because....
I beleive it needs a new tensioner pulley
the pulley was making a weird noise one morning and after further investigation the timing belt has a bit of slack.
Ever since discovering this i havent driven the car just to be sure!
i beleive the timing will need to be redone aswell because the CAS was removed to check the belt
Drove like a dream before; most probably will still drive like a dream now, however dont want to risk a possible catastrophe!
it would be safer to say it needs to have the 100,000 km service as a precaution while the whole front cover is off
to have the tensioner bearing (and everything associated) changed before driving anywhere
There is also a minor dent along the drivers side door and rear fender were the front wheel picked up something.
after spending all this money of the engine and personal issues that have come up i cant afford to spend any more on this beast!
i am way too busy atm to do organise a 100k km service. wont be free until february 2014, so the car is up for sale until then !
if you want to view the car give me a text on [removed]
**EOI for some stock 34 gtt parts:
Bonnet
Front Guards
Standard Rear Wing
All parts are factory black, fenders and bonnet in very good condition (will double check for light surface scratches), standard wing's paintwork has seen better days and is fairly faded on the top of the wing blade (will need a respray).
**The following are also up for grabs:
GENUINE Impul gtt front bar
Replica 34 gtr spoiler with carbon wing blade
Impul front bar is a little rough as it had a confrontation with a kangaroo, but won. The paint has cracked and there is very slight frays on the fibreglass around the grill, but otherwise structurally perfect.
Replica spoiler has never been fitted as I'm waiting on carbon wing stands from a group buy on here. The carbon blade is very good quality but the standard wing stands didn't align properly with my boot. It's a dead easy fix, but I haven't been bothered to address it.
If the carbon stands fit properly I may keep it (unless the right price is agreed upon)
I will work out pricing asap, just gauging interest for now.
PM for info and pics
Selling some R32 GTR (RB26DETT) gear off. and a couple of 34 bits as I need cash
New Harmonic Balancer - ATI (Super Damper), - 500HP - $400
  • Eliminates torsional crankshaft vibrations
  • Exceeds SFI 18.1 specs
  • Black zinc chromate finished
  • Tunable, rebuildable, and extremely efficient at ALL RPM
  • Laser engraved 360° timing marks
New OEM Injector Ballast Resistor - $100
New Dspeed smoked indicators - $300
Near New BM57 (ABS) - $300 (couple of hundred KM's)
New SRI Front Upper adjustable control arms - $175
New SRI Cold Air Box Kit for R34 GTT - $140
^good savings^
Used parts in good working order and condition
Denso 720 Injectors - $350
Nismo Oil cap in Packaging - $75 (Brass/Rose in colour)
Steering Rack - $100
Power Steering pump - $100
Starter motor - $100
Front Bar Mesh - $50
Front Seat belts vgc - $150
Cusco Strut Brace (round) - $50
5Zigen JASMA exhaust muffler - oval (axle back) $175. As new.
Professional Custom made Exhaust true 3" cat back with Mid muffler & Oval tail muffler (mandrel bends etc..) under 1000kms no damage - $450
HID's for N1 headlights with globes & ballasts - $100. Fitted and used for a few weeks.
Considering parting with:
- NISMO Blank Keys in packaging - 1 x 8 point, 1 x 10 point. Open to exceptional offers (via PM only).
- New Genuine N1 front bar with OEM Lip and N1 Vents in Original OEM Packaging - $900 (as a package only)
All + Postage.
PM me and I will get back to you.
(more parts may be added so check back)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
