intake manifold (with injectors and fuel rail )
both rear lower control arms
clutch brake pedal plus master cylinders
cas
tail lights
fuel pump
adjustable front tie rod ends
take the lot for $150
s2 r33 front seats $100 for both
3 out of 4 will line up, you just need to extend one of them an inch or so i think.
There is a write up on a few different forums IIRC
Passengers is really good, drivers has a slight split in the seam of the RHS of the drivers bolster but 20 cents worth of blue thread and a needle stolen from your nan should fix it. I shampooed them not long ago. I can take some pictures if you are interested.
PM'd you :)
Brand New Unopened 2" SPECO 533-03 Street Series BOOST GAUGE - $50.00 $40.00 pickup or $50.00 Posted.
Want it Gone.
Buy the flamin mongrel ya dream boats!
For the love of rajab. :worship:
17x8 and 17x9 35p OZ Racing wheels, have 235 and 255 used semi slicks.
$650
1403366_10152005768391387_202506468_o.jp
Water/methanol injection kit with water/methanol mix and methanol.
$300
1403293_10152008410736387_737375936_o.jp
Nissan Micra Super S 1995, has new clutch, nismo engine mounts, ball joints and driveshafts. No rego.
$1000
Bolt on supercharger setup for 1uzfe, needs intercooling or a new pulley made to lower boost from 22psi.
$3000
1093920_10151839688001387_293295834_o.jp
All located in Tuggeranong
0435 626 691
$650
$300
$1000
$3000
0435 626 691
I want the micra, but no kesh :(
661 Carbon fibre full face pushbike helmet, size MEDIUM. Purchased brand new, worn 2 or possibly 3 times, never actually utilised (ie never had a crash while wearing). Minor cosmetic scratches sustained while moving house; in no way affects safety, you can barely see them. Helmet is the same as below picture.
$200, will post at buyer's expense
Mace "swat jacket" body armour, unsure of size (can check). Worn only once, never utilised either. Comes with detachable armadillo-style spine protector. Same as pic below.
$150, will post at buyer's expense
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
