I did for the helmet, and can get the size of the jacket for anyone actually interested in buying it. I'm 173cm tall 78kg, average upper-body measurements, and it fits just as well as when I bought it weighing only 70kg.
Yeah but I want to head down the coast this weekend and my exhaust it leaking and too low to the ground.
Tried to go to the exhaust place today and he said that it's too large for him to work on
Heard that one a few times. She had no say on the matter anyway.
  • Like 1
Roadway is not busy today, got mine done thismorning.
And he wont say its too large, lol.
Too large to work on... thats what she said...... :P
Edited by D.I.Y. Mik
600 CC Siemens Injectors for RB25DET R34 NEO Motor.
Body Design: STANDARD-length, composite plastic
Flow rate: 600 cc/min, 57 lbs/hr at 43.5 psi
Injector type: Saturated
Configuration: Standard Length - 2.5 in., 2.0 in. o-ring to o-ring
Connector type: U.S. CAR (New-style V=EV6 / Oval / LS2)
Fuel Nozzle: Single-hole, tiny droplet
Resistance: 12.5 Ohms, high resistance
Diameter: 16 mm
O-rings: Viton, Top and bottom, 14.5 mm
Part number: 109958
SETS FACTORY-MATCHED TO BETTER-THAN 2%
Sell for $300
0421 669 603
For sale:
Greddy catch can. 1L capacity. - $50
HKS Super blow off valve with pipe (This is the first gen model). Suit Rb26dett. These are non flutter type (Just dumps the air in 1 go) Atmospheric. These are the high load BOV for use with more power -$100 for both with the pipe.
Standard RB26dett Injectors - $250. Also have fuel rail to suit if need be.
Standard R32 GT-R Airbox with new filter. $200
Also have an old boost controller with everything for $50. Can check what it is if anyone is interested. Worked fine before i put my new one in.
Also have Two apexi pod Filters (used) someone can have both for $50.
Can get pics of the other items if people interested.
- Apexi SAFC (Black) - $250 used
- Greddy Profec B Spec 2 boost controller- $300 used
- GCG GT30 0.82 rear housing (internal wastegate) - $350-$400 NEW
- wastegate actuator 12PSI w/bracket - $100 NEW
- 5 bolt dump pipe - mild steel - $150 NEW
- SOLD
- Oil cooler/relocator kit (fits RB) - $180 used - SOLD
- R32 GTR wing - Dark metallic blue - $150 used
- Kinugawa TO4E oil drain - $50 NEW
- SOLD
- HKS SSQV (comes with circlip/2bolt mount to fit RB25DET standad BOV position $100 used
- Stock RB25DET ECU - $120 used
- Stock RB25DET Air Flow Meter - $120 used
- 2x Federal 595SS 245/45ZR18 (lots of tread) - $100 used
- Tein HA Coilovers to suit R32 GTST rear pair(need shocks rebuilt) - $100
- Trust Airinx air filter (should suit stock skyline AFM)- $100
- Nissan R31 Skyline Wagon (Series 3) - will confirm K's (under 200), motor very healthy, very tidy apart from a few small dents, Auto, Cruise Control, Alpine CD Player - $1200 ono
All prices quite negotiable. please give me an offer.
PM, text or call 0431900505.
may forget to check this for a while so please PM, text or call
will post pics eventually, can send pics if requested
Would prefer local sale
located in Woden, ACT
Cheers
Simon
post-27427-0-78494500-1365815252_thumb.j post-27427-0-99454600-1365815254_thumb.j post-27427-0-07171800-1365815264_thumb.j post-27427-0-04689000-1365815266_thumb.j post-27427-0-52514000-1365815273_thumb.j post-27427-0-44306300-1365815275_thumb.jpost-27427-0-50180600-1365815277_thumb.j post-27427-0-61105500-1365815279_thumb.j post-27427-0-52966400-1365815281_thumb.j post-27427-0-48292800-1365815283_thumb.j post-27427-0-70125000-1365815385_thumb.j post-27427-0-55363300-1365815388_thumb.j post-27427-0-47027000-1365815392_thumb.j post-27427-0-22023400-1365815394_thumb.j
    • Before I commit to it as I already have the wastegate off the car, would you change it to the 9psi spring instead of the 12, or whack it back on now and try your suggestion?   Edit: Actually I might just swap the spring and see what the logs say after another few pulls, as we know it's still spiking without the Mac valve in the picture so I need more data without the Mac valve trying to combat the issue.
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
    • Car has been sold and I am now selling leftover parts. Prices are non-negotiable as I will sell to my mechanic if it won't sell here. Prices are firm except for the Random Parts listed at the very bottom. All parts are genuine except for the S-Tune front bumper. Volk Racing TE37SL 19×10.5″ +12 5×114.3 pressed graphite with P-Zero 275 30 19 tyres [USED] $4,500 Wheels are in perfect condition, have been sitting in my garage for the past 6 years. Tyres still have 90% tread, but since they're now old, I would not recommend you drive hard on them. K-Sport Super Sport External Reservoir Coilovers (made to order) [NEW] $2,500 Front spring rate 14kg, Rear spring rate 7.5kg Fork Type. You can read all about it here (https://www.k-sportracing.com/product_detail.php?Key=12). I was going to start tracking the GTR, but never got around to it. Paid $3500 (after USD conversion and taxes). HKS Kansai Service Tower Bar [NEW] $500 Never fitted in the original Japanese box. R34 GTR S-Tune Fibreglass Bumper [NEW] $500 No mesh - No Box - No damage - just dusty. Nitto RB26 Clear Timing Cover [NEW] $50 Couldn't fit RB2630 due to bonnet clearance. HKS Piping Kit Special Type (BNR34) & Apexi Power Intake Air Filter Kit & Password JDM Adapter [USED] $1,000 Missing some rubber hoses and supports, but you get what you see. Nismo NE-1 Weldina Turbo Back Exhaust & Custom 3.5"straight pipe [USED] $1,000 Needs some love, but perfect for those who want to go back to OEM+. Bayside Blue Aluminium Vspec Bonnet/Hood [USED] $700 Came off my GTR. Unfortunately, the tips have been slightly ground down. It will need some repairing. Bride Low Max Super Seat Rails [USED] $350 The price is for both sides. Will post pictures when I get a chance. Random Parts [USED] - negotiable Standard rb26 cams (intake and exhaust) $10 Stock amber front indicators $10 Standard GTR bumper lower side grills $10 Stock amber side indicators $10 Nismo Sports Resetting ECU $50 Water reservoir $10 Stock airbox mouth $10 Stock fuel rail $10 Stock coilovers from R34 GTR Vspec $100 PM me which items you are interested in. I do work 9-5, so I will be responding daily at best. Best time for pick up is after 5 and before 7 on weekdays, or i can work something out on weekends. I will only accept cash or PayID. Pick up only - located Epping NSW area.
