Brand new OEM centre vents. Suit R32 (a lighter grey). Most likely GTS-t
Could paint black if you have the black stereo surround for GTR
Yours for the low price of $70 (normally $149)
I need dark grey :/
barmp
For sale:
HKS Super blow off valve with pipe (This is the first gen model). $100 for both with the pipe.
Standard RB26dett Injectors - $200 Price drop
Standard R32 GT-R Airbox with new filter. $150 Price drop
Also have Two apexi pod Filters (used) someone can have both for $50.
Hyosung GT250R $1200 for SAU members Still has rego. Runs perfectly. Rubbed back for painting fairings. Only needs rear tyre to pass rego.
I have lots of space, happy to pick them up instead of them going into a bin.
  • cuong nguyen has pmed me saying hed like the shocks but if he doesnt end up taking them you are welcome to come grab whatever you want.
I also have a pair of 17" rims that are just sitting around doing nothing. Pretty sure they are either 8.5" or 9" wide and suit either front or rear gtst offset. Can get pics and more details if anyone is interested. Actually i think if you look back through one of my for sale threads i was trying to flog them off a while back.
Anyway they are also free now if anyone wants them. Could be good for skids or track wheels...
have R33 parts -boot lid $50 and interior - seats and centre console $20 each, rear wing $30., rear tail lights $50 . fuse boxes, rear drive line and arms.. master cylinder $50 other odd bits.
have pink label afm and apexi pod filter all as one piece $70 can separate.. r33 gtst ecu $150
R33 stock clutch heeps on it $100.. r33 exhaust cat back with cannon from dump was 90db on my car and flowed 320kw no restrictions.. $200ono
pls pm me as i dont check back here often.
BUMP
- Apexi SAFC (Black) - $250 used
- GCG GT30 0.82 rear housing (internal wastegate) - $350-$400 NEW
- HKS SSQV (comes with circlip/2bolt mount to fit RB25DET standad BOV position $100 used
- Stock RB25DET ECU - $120 used
- Stock RB25DET Air Flow Meter - $120 used
- 2x Federal 595SS 245/45ZR18 (lots of tread) - $100 used
- Tein HA Coilovers to suit R32 GTST rear pair(need shocks rebuilt) - $100
- Trust Airinx air filter (should suit stock skyline AFM)- $100
- Greddy Profec B Spec 2 boost controller- $300 used - SOLD
- wastegate actuator 12PSI w/bracket - $100 NEW - SOLD
- 5 bolt dump pipe - mild steel - $150 NEW - SOLD
- Oil cooler/relocator kit (fits RB) - $180 used - SOLD
- R32 GTR wing - Dark metallic blue - $150 used
- Kinugawa TO4E oil drain - $50 NEW
- SOLD
- Nissan R31 Skyline Wagon (Series 3) - $1200 ono - SOLD
All prices quite negotiable. please give me an offer.
PM, text or call 0431900505.
may forget to check this for a while so please PM, text or call
will post pics eventually, can send pics if requested
Would prefer local sale
located in Woden, ACT
Cheers
Simon
post-27427-0-78494500-1365815252_thumb.j post-27427-0-99454600-1365815254_thumb.j post-27427-0-07171800-1365815264_thumb.j post-27427-0-04689000-1365815266_thumb.j post-27427-0-52514000-1365815273_thumb.j post-27427-0-44306300-1365815275_thumb.jpost-27427-0-50180600-1365815277_thumb.j post-27427-0-61105500-1365815279_thumb.j post-27427-0-52966400-1365815281_thumb.j post-27427-0-55363300-1365815388_thumb.j post-27427-0-47027000-1365815392_thumb.j post-27427-0-22023400-1365815394_thumb.j
BUMP
- Kinugawa TO4E oil drain - $50 NEW - SOLD
Cheers
Simon
Noooooo, don't sell my SAFC!
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
