Brand new OEM centre vents. Suit R32 (a lighter grey). Most likely GTS-t
Could paint black if you have the black stereo surround for GTR
Yours for the low price of $70 (normally $149)
I need dark grey :/
barmp
For sale:
HKS Super blow off valve with pipe (This is the first gen model). $100 for both with the pipe.
Standard RB26dett Injectors - $200 Price drop
Standard R32 GT-R Airbox with new filter. $150 Price drop
Also have Two apexi pod Filters (used) someone can have both for $50.
Hyosung GT250R $1200 for SAU members Still has rego. Runs perfectly. Rubbed back for painting fairings. Only needs rear tyre to pass rego.
I have lots of space, happy to pick them up instead of them going into a bin.
  • cuong nguyen has pmed me saying hed like the shocks but if he doesnt end up taking them you are welcome to come grab whatever you want.
I also have a pair of 17" rims that are just sitting around doing nothing. Pretty sure they are either 8.5" or 9" wide and suit either front or rear gtst offset. Can get pics and more details if anyone is interested. Actually i think if you look back through one of my for sale threads i was trying to flog them off a while back.
Anyway they are also free now if anyone wants them. Could be good for skids or track wheels...
have R33 parts -boot lid $50 and interior - seats and centre console $20 each, rear wing $30., rear tail lights $50 . fuse boxes, rear drive line and arms.. master cylinder $50 other odd bits.
have pink label afm and apexi pod filter all as one piece $70 can separate.. r33 gtst ecu $150
R33 stock clutch heeps on it $100.. r33 exhaust cat back with cannon from dump was 90db on my car and flowed 320kw no restrictions.. $200ono
pls pm me as i dont check back here often.
BUMP
- Apexi SAFC (Black) - $250 used
- GCG GT30 0.82 rear housing (internal wastegate) - $350-$400 NEW
- HKS SSQV (comes with circlip/2bolt mount to fit RB25DET standad BOV position $100 used
- Stock RB25DET ECU - $120 used
- Stock RB25DET Air Flow Meter - $120 used
- 2x Federal 595SS 245/45ZR18 (lots of tread) - $100 used
- Tein HA Coilovers to suit R32 GTST rear pair(need shocks rebuilt) - $100
- Trust Airinx air filter (should suit stock skyline AFM)- $100
- Greddy Profec B Spec 2 boost controller- $300 used - SOLD
- wastegate actuator 12PSI w/bracket - $100 NEW - SOLD
- 5 bolt dump pipe - mild steel - $150 NEW - SOLD
- Oil cooler/relocator kit (fits RB) - $180 used - SOLD
- R32 GTR wing - Dark metallic blue - $150 used
- Kinugawa TO4E oil drain - $50 NEW
- SOLD
- Nissan R31 Skyline Wagon (Series 3) - $1200 ono - SOLD
All prices quite negotiable. please give me an offer.
PM, text or call 0431900505.
may forget to check this for a while so please PM, text or call
will post pics eventually, can send pics if requested
Would prefer local sale
located in Woden, ACT
Cheers
Simon
post-27427-0-78494500-1365815252_thumb.j post-27427-0-99454600-1365815254_thumb.j post-27427-0-07171800-1365815264_thumb.j post-27427-0-04689000-1365815266_thumb.j post-27427-0-52514000-1365815273_thumb.j post-27427-0-44306300-1365815275_thumb.jpost-27427-0-50180600-1365815277_thumb.j post-27427-0-61105500-1365815279_thumb.j post-27427-0-52966400-1365815281_thumb.j post-27427-0-55363300-1365815388_thumb.j post-27427-0-47027000-1365815392_thumb.j post-27427-0-22023400-1365815394_thumb.j
BUMP
- Kinugawa TO4E oil drain - $50 NEW - SOLD
Cheers
Simon
Noooooo, don't sell my SAFC!
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
