Brand new OEM centre vents. Suit R32 (a lighter grey). Most likely GTS-t
Could paint black if you have the black stereo surround for GTR
Yours for the low price of $70 (normally $149)
I need dark grey :/
barmp
For sale:
HKS Super blow off valve with pipe (This is the first gen model). $100 for both with the pipe.
Standard RB26dett Injectors - $200 Price drop
Standard R32 GT-R Airbox with new filter. $150 Price drop
Also have Two apexi pod Filters (used) someone can have both for $50.
Hyosung GT250R $1200 for SAU members Still has rego. Runs perfectly. Rubbed back for painting fairings. Only needs rear tyre to pass rego.
I have lots of space, happy to pick them up instead of them going into a bin.
  • cuong nguyen has pmed me saying hed like the shocks but if he doesnt end up taking them you are welcome to come grab whatever you want.
I also have a pair of 17" rims that are just sitting around doing nothing. Pretty sure they are either 8.5" or 9" wide and suit either front or rear gtst offset. Can get pics and more details if anyone is interested. Actually i think if you look back through one of my for sale threads i was trying to flog them off a while back.
Anyway they are also free now if anyone wants them. Could be good for skids or track wheels...
have R33 parts -boot lid $50 and interior - seats and centre console $20 each, rear wing $30., rear tail lights $50 . fuse boxes, rear drive line and arms.. master cylinder $50 other odd bits.
have pink label afm and apexi pod filter all as one piece $70 can separate.. r33 gtst ecu $150
R33 stock clutch heeps on it $100.. r33 exhaust cat back with cannon from dump was 90db on my car and flowed 320kw no restrictions.. $200ono
pls pm me as i dont check back here often.
BUMP
- Apexi SAFC (Black) - $250 used
- GCG GT30 0.82 rear housing (internal wastegate) - $350-$400 NEW
- HKS SSQV (comes with circlip/2bolt mount to fit RB25DET standad BOV position $100 used
- Stock RB25DET ECU - $120 used
- Stock RB25DET Air Flow Meter - $120 used
- 2x Federal 595SS 245/45ZR18 (lots of tread) - $100 used
- Tein HA Coilovers to suit R32 GTST rear pair(need shocks rebuilt) - $100
- Trust Airinx air filter (should suit stock skyline AFM)- $100
- Greddy Profec B Spec 2 boost controller- $300 used - SOLD
- wastegate actuator 12PSI w/bracket - $100 NEW - SOLD
- 5 bolt dump pipe - mild steel - $150 NEW - SOLD
- Oil cooler/relocator kit (fits RB) - $180 used - SOLD
- R32 GTR wing - Dark metallic blue - $150 used
- Kinugawa TO4E oil drain - $50 NEW
- SOLD
- Nissan R31 Skyline Wagon (Series 3) - $1200 ono - SOLD
All prices quite negotiable. please give me an offer.
PM, text or call 0431900505.
may forget to check this for a while so please PM, text or call
will post pics eventually, can send pics if requested
Would prefer local sale
located in Woden, ACT
Cheers
Simon
post-27427-0-78494500-1365815252_thumb.j post-27427-0-99454600-1365815254_thumb.j post-27427-0-07171800-1365815264_thumb.j post-27427-0-04689000-1365815266_thumb.j post-27427-0-52514000-1365815273_thumb.j post-27427-0-44306300-1365815275_thumb.jpost-27427-0-50180600-1365815277_thumb.j post-27427-0-61105500-1365815279_thumb.j post-27427-0-52966400-1365815281_thumb.j post-27427-0-55363300-1365815388_thumb.j post-27427-0-47027000-1365815392_thumb.j post-27427-0-22023400-1365815394_thumb.j
BUMP
- Kinugawa TO4E oil drain - $50 NEW - SOLD
Cheers
Simon
Noooooo, don't sell my SAFC!
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
