OK, In the 3+ years since I got my 33, I have Gathered WAY TOO MUCH STUFF!
This is not all of it but it's a start, Prices are ono...
Buy my Stuff and Things!
R33 S1 Turbo, Minimal shaft play but condition unknown as unused by me. $150. SOLD.
R33 S2 Turbo, Minimal shaft play but condition unknown as unused by me. $180.
R33 side indicators. $15 / pair... (more than 1 pair available)
Stock Rubber intake Pipe for GTS-t $15 (more than 1 available)
R33 Coupe Rear Garnish (Clear) $50.00
Various NISSAN Relays $10 each.
GTR BOV $80 (More than 1 Available) 1 SOLD Pending Payment/Pickup.
Some piping for GTR Bov also.
GTS-t Bov $40
R33 Crossover J pipe $20 (more than 1 available)
Stock R33 GTS-t Dump $20
New Never Used Stainless Split Dump Pipe $80
Stock R33 GTS-t Frontpipe and Gutted Cat $20
3" GTS-t Frontpipe larger section welded in the middle. Ugly but Effective. $40
Stock Series 2 R33 Coilpacks $80 / set of 6 (more than 1 set available)
Stock R33 Side Mount Cooler $50.
R33 4door Tail lights and Garnish - Both Series 1 and Series 2.
R33 Coupe Series 2 Wing (White) $100
R33 4door Wing (Silver) $100
R33 GTS-t Airbox and Snorkle $100
**More will be added in time.
**R33 GTS-t RB25DET Rocker Covers $100 pair, I might even clean them for you.
**R33 GTS-t Stock ECUs Series 1 and Series 2... $100 Each.
If it's Not Listed, I may have one... Just ask.
PM is best. Pics can be provided.
I have a bit for sale.
Our move to melbourne looks like it is going to be happening a lot sooner than we thought and i really don't want to cart this stuff with me so it's up for grabs.
I have a staggered set of forged 17'' Rays Volk Challenge wheels fronts are 17x8 + 32 i believe rears are 17x9 +40
The paint is coming off all 4 but with a strip back and spray they will looks schmick. 3 have very very minor scuffing, one is a bit more severe but if you get them fixed up you will never know. I was going to keep them but now that i'm moving i would rather have the cash and less stuff to move.
They have some average 235/35 's fitted to them rears on 80% fronts maybe 30%.
Looking for $600 ono
I have a front mount kit and pipe work to suit an r34 and should fit r33. It is painted purple but should be easy enough to strip or paint black if you arent man enough for it. You will need to trim your fan for this one. The core is really thick on this one. Will get measurements tomorrow.
Looking for $200 ono
I also have a metal cold air box in black to suit an r34 gtt.
Only used it for a few days until I went to a return flow intercooler.
If you have a return flow or side mount you should be able to use this by just making a few cuts.
I didn't because I already had a high octane old air box which suited.
Comes with screws and nuts.
Looking for $115 ono
I also found these at the back of the shed.
They are an old school set of 15'' x 6'' and 6.5'' works ewing mesh in 4 stud 114.3 pcd.
They have seen better days but you can pull the centres out and have them sand blasted and give the rim a good polish.
Would look awesome in gold or bronze. The only issue with these is that last time i moved i lost the key for the centre caps.
Should be easy to source from RHD japan or something like that. They have 205 55 tyres of them i believe. one pair is about 55% the others are almost gone.
Will post more up as I go through the shed.
Edited by azathoth
Also have a Turbosmart BOV (not sure what type buy it's pretty big) has adjustable spring pressure and comes with adaptor plate to fit in the stock BOV position on the crossover pipe.
Will post up picture tomorrow.
$140 ono
Old School Skate Decks...
I have 5 old Classic Skateboards that I don't need.
These are from back in the day. (20 - 25 years old)
Condition ranges from Not Too Bad to Pretty Damn good. :P
Collectables for the right person.
Mark Gonzales
Ron Allen
Bones Ripper
Steve Caballero
Christian Hosoi
post-78856-0-25023300-1387188724_thumb.jpg post-78856-0-17523500-1387188705_thumb.jpg
$200 for the lot.
Hi guys
Currently looking at selling my RB20DET ENGINEERED 1989 R31 Skyline Silhouette so I can try something different. I've owned the car for roughly 3 years now, mostly using it at Wakefield Park track days. It's well setup for both grip and drift while still being able to drive around town comfortably and legally as the car has an engineers certificate for the modifications performed. Oil has been changed after every track day the car has done, roughly every 2000km's. The only reason I stopped using it as a daily driver was someone tried to steal it once and as I work nights I wasn't comfortable leaving it out anymore. The body could do with some love but the paint for the most part is still in good condition which is quite rare for a 20+ year old red car!
** NOTE car will be sold WITH Road Worthy Certificate **
Here is a list of parts although I've probably forgotten somethings.
1989 Series 3 Silhouette
Red over silver paint
350,000 km's on chassis
200,000 km's on engine (roughly)
Engine:
R32 RB20DET
Front mount Intercooler
Pod filter
3 inch cat back exhaust
Slightly re-tuned factory ecu
Stock boost
140RWKW
Driveline:
RB20 Gearbox
Exedy heavy duty clutch
Short shifter
Kaaz 2 Way and 4.11 Gears (diff rebuilt less than 10,000 k's ago)
Suspension:
Front.
S13 BC BR type RH coilovers
S13 LCA's and knuckles
Garage 7 SMM Offset R31 Conversion Rack Spacers
GP Sports S13 tie rods + ends
Custom adjustable castor rods
Whiteline swaybar
Whiteline strut brace
Reconditioned steering rack (less than 10,000 k's ago)
Lots of new Bushes
Rear.
Whiteline swaybar
Adjustable panhard rod
Brakes:
R32 GTS-t front calipers
GTS rotors
Stock rear
Bendix ultimate pads Front
QFM Super X Rear
Modified handbrake
Exterior:
Rising sun bonnet
Removed rear spoiler but comes with the original silhouette one
Passenger fender in need of paint
Interior:
330mm deep dish steering wheel
Autometer water temp gauge
Import drivers seat
Basic stereo
Battery relocated to the boot
Wheels:
17x7's with brand new tyres (not pictured)
Price $6,500 WITH RWC
Now that I have started packing early for the move and the house is full of boxes I am more than happy to take $450 for the rims which is also more reasonable.
I need somewhere to put these boxes and the wheels are in the way. Feel free to throw me offers on the other stuff too.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
