My old compressor for sale:
$50 Direct drive, 2hp, 240v, Italian made.
I'll take it mik
Can I come get it next week some time?
If this does not eventuate...
I call Sloppy Seconds! :D
:excl:
Id like to point out its quite small.
It wont run air tools, like a sander or grinder.
It can just run a rattle gun enough to get the wheels off, but you have to wait for it to fill up after about 5 seconds of rattle gun use. It cant get the flywheel bolts off, not enough air.
Its ok for filling tyres, blowing dust off small areas, airbrushing.
What else can you do with a small compressor? Not much.
This is my solution: http://peerlessproducts.com.au/products/single-phase/00257
Peerless p14, its the most flow i can find on 10 amps.
275lpm, thats nearly 10cfm! And heaps quieter than the SIP
This sucker will run everything i want, ive wanted a good compressor since forever.
Edited by D.I.Y. Mik
Have a Gcg high flow that I'm looking at selling as I have upgraded to a bigger turbo. It's was on my car for about 4months and I made 242kw on 20psi. Turbo is in very good condition can come have a look for yourself.
Prefer local buyer but will post at buyers expense.
Pm me or msg me on 0406376307 for quicker response.
Looking for $800 firm as I don't need to sell, can always keep for one of my other 33's
I'm located in Canberrapost-22213-13923251121022_thumb.jpgpost-22213-1392325129838_thumb.jpg
Mik why you not buy the peerless from me
<\3
Doh! >_< (facepalm)
Because internet told me only one place, total tools.
Will search better next time.
Curious, how much do you sell them for?
Others may be interested as this compressor is the biggest on 10amp (regular domestic power plug)
If anyone sees my skyline or knows who bought it text me on 0423402784
mum kicked me out of home and I got a text from my aunty saying that mum sold my car
Without my signature on the rego papers
if anyone sees him or knows him get him to call me
Unless I can get my baby back mum will never hear from me
just report it at stolen.
Hey guys im selling my Polished plazmaman intake for a Rb25det
if anyone is interested let me know.
$750
Bought it 2nd hand from another member on here but never used it, just try fit it.
Only reason selling it as i have no job and now uni has started so i need money very badly.
Edited by 5hiv
I'm located in Canberraattachicon.gifImageUploadedByTapatalk1392325109.261216.jpgattachicon.gifImageUploadedByTapatalk1392325125.161123.jpg
lol
lol
Sold
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
