Hi Everyone,
Not sure if this is the right place to advertise this - let me know if not. Ad is also on 'Whole Cars sale page' with pics etc.
Immaculate R32 GTR for sale
Spent plenty as you do, someone else's chance to enjoy.
333kw (At all Four @ 21 PSI.)
For those that like the detail, let me know and I can provide you with the full list (all internals no expense spared.) Shortened version as per below;
Fully overhauled engine, Balanced and Blue printed (Engine built by Pace Pace Motorsport in Melbourne Tuned by Ed @ Autotech Canberra)
Tomei cams (260-9.15)
Trust high volume sump
Remote oil filter and oil cooler
25/30 parallel HKS Turbos
CES ceramic dump pipes and full high performance exhaust system
Nistune Ecu
HKS Launch Control & torque splitter
Turbo smart eboost
Overhauled gearbox
Excedy triple plate clutch
Koni adjustable suspension
Full customer GTR interior
18 inch Simmons Alta wheels
No money to spend and everything works. Low k's since engine build (has 173,000 on the clock.)
Currently engineered and registered in NSW. All extras and spares supplied with car
Located NSW Far South Coast - Will travel to Canberra for genuine inspection.
$34,900
Reasonable genuine offers considered
post-32547-0-09160100-1420591279_thumb.jpgpost-32547-0-26610600-1420591288_thumb.jpgpost-32547-0-24322700-1420591240_thumb.jpgpost-32547-0-52976600-1420591252_thumb.jpgpost-32547-0-03544100-1420591265_thumb.jpgpost-32547-0-37633700-1420591306_thumb.jpgpost-32547-0-89583200-1420591314_thumb.jpg
Hi Guys,
R32/R33 GTR Apexi Power FC (without Hand controller) $600
2x Z32 AFM (Practically Brand new, done like 2000km) $250 for the pair.
Also still have a set of standard injectors, Standaird Airbox (missing 1 clip) and a set of Apexi pods. PM for more details.
Have an Ogura twin plate clutch here with plenty of meat left on it still. Not using it anymore as I've gone to a quad plate.
Suitable for an R32 GTR.
Don't have the bearing from the centre but they're not that expensive or hard to get. $400, prefer local sale.
Push type
^^ Lots of interest but I still have this and want it gone!
I have some (badly) polished cam covers to suit rb26. Have both cam covers, timing cover, plenum and twin turbo pipe. Dont have a coil pack cover though. Ideally want to see if someone wants a head start instead of polishing theirs. Will swap for painted ones (dont require plenum or twin turbo pipe though). Will get pics when im home in a few weeks if required
god damn why cant it be the passenger side speaker cover!!
Should be able to help you out Nate
Replacing door card in my 32/4 and I'd say the speaker cover will fit
Let you know when it's swapped over
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
