Hi people.
As you may or may not have heard/read on "Ask Bird the wise man thread" I was originally in the market with $30k looking for a FG XR6T or FPV.
However shit happened (for one thing certain parts of the Skyline is broken again & since I'm retarded & can't use a spanner this means it is that time of the year in my life to pour crap load of $$$ to get it fixed) & my budget has dropped to $20k, which at this range can only get me old BA or earlier BF XR6Ts which all had the aging 4 speed auto box, which from what I have read is garbage & I'm trying to avoid.
So I started to look at some Jap alternative relatively powerful family sedans & with our resident mod mad082 always mentioning his old Mangna with cat back at the drags put a time which can rivial a stock GTS-T, the 380 has caught my attention.
The fact that they have horrible resale value is a big + for me, quick carsales search shows that I can get upper range GT /VXR models with all the fancy crap (leather, sun roof, reverse sensors etc etc) for $16-18k or so & all the base models (ES) hover around the $10k-$12k range.
This compared to the Aurion (the other one I was looking at) which seem to only start at close to $20k for base models.
So has anyone owned one of these? & what is your opinion on it?
Also how well does it respond to mods (or at all?).
Cheers.
Edited by Mayuri Krab
https://www.sau.com.au/forums/topic/399851-mitsubishi-380/
Just an alternative if you're after an auto fwd.
Maximas also depreciate badly.
My 85 yr old Mum decided she needed to downsize. Her 1997 GXE only has 70,000km on it and couldn't sell it for more than $5K > gave it away to my nephew. It has a good engine.
She was also looking at Magnas at the time.
One thing you may not know ( out of interest ) is that in the mid 90s, Nissan brought in just a few manual versions too.
https://www.sau.com.au/forums/topic/399851-mitsubishi-380/#findComment-6351920
Yep, my wife has one.
A 2005 GT. It has everything except a reversing camera (has sensors).
Enough power although it is strangled a little by the intake scoop and the rear muffler (easy replacements).
Car is a very nice cruiser and has pretty good economy for a big 3.8L sedan.
They are quite large though (bigger than a VE).
Don't get anything less than an VRX, there is a big difference between the bottom two (ES, SX) and the top two (VRX, GT) spec cars.
Forget about tuning though, the ECU is so far unchippable/flashable and only one piggyback "works".
Nice car, just need to chuck a transmission cooler on it :)
Edited by iamhe77
https://www.sau.com.au/forums/topic/399851-mitsubishi-380/#findComment-6352605
Hi people.
The BF xr6t autos are all 6 speed.not 4 speed and you should be able to get a decent one for 20k. I'd love to get 20k for my 06 with 75k on it but I just wont. I know being over west changes the market a bit though.
As for the 380 I'vr got a mate with an early model and it seems like a decent car, nice features, comfortable, reasonable pull.
https://www.sau.com.au/forums/topic/399851-mitsubishi-380/#findComment-6354136
The BA had the 4 speed did it?
Edited by iplen
https://www.sau.com.au/forums/topic/399851-mitsubishi-380/#findComment-6355249
Aurion Sportivo 20k?
even if its 22k, theres no comparison
Safety features up the wa- zoo, 200 killer wasps, huge boot, plenty of interior space, excellent resale, well trimmed, good looking... and its a fcuking toyota
i defy you to choose a better bang for your buck automobile
Edited by ctjet
https://www.sau.com.au/forums/topic/399851-mitsubishi-380/#findComment-6355731
and they sound pretty shit hot. one went past work with a decent exhaust on it. has a similar sound to the RB (sounds better than a natro skyline though)
https://www.sau.com.au/forums/topic/399851-mitsubishi-380/#findComment-6356256
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
