you always need to disable O2 feedback whilst tuning, then re-enable it once you're done.. however I just leave it off completely on the idle/cruise cells.
Yeah I mean leave it off and manually tune stoich at cruise? Doesn't it make it impossible to get it right all year around, eg humidity, altitude changes temperature etc?
that's right, but how often are you going to drive to the alps? lol
and remember, RB25DETs and SR20s don't have an intake air temp sensor so you can't correct much anyway.
If you're concern about all those factors just tune it to stoich, then re-enable the O2 feedback.. however I do find that the stock ECU takes a while to stoich hence I just leave it off usually
Altitude and temperature should have no impact except maybe that as you go up in elevation then the turbo has to work harder to get the same boost, so exhaust manifold back pressure will increase and the compressed air temperature should also increase, which might require some richening of the mix to stave off pinging.
Humidity will have an effect, but it is probably smaller than the resolution of tuning anyway - or at worst only about like having the mixtures 0.3 or so :1 wrong. Well I'd hope so, without knowing for sure. But there is not a massive range in the mass% of water in air between 0% and 100% RH. At normal temperatures (like 20-30°C) you can only hold about 3% water in air at 100% RH. So assuming you tune near the middle of that range then you only have a possible swing of +/- 1.5% or so from where you tuned it. Enough to be noticeable perhaps, not enough to cause big dramas.
I got a microtech and my idle control valve works and my revs increase when I turn on ac
it's not closed loop however it "may" appear to work correctly but it's far from perfect
You set your desired idle rpm, and it will control the valve to acheive that rpm, air con on it can idle up. Never had an issue with mine either.
  • Like 1
Closed loop idle control and closed loop mixture control are 2 different things anyway.
Lol to be honest I got no idea what closed loop idle control is - I read it doesn't increase idle when you turn on ac, so I argued that mine does....
Can someone provide a brief explanation of what closed loop idle control and mixture is?
Closed loop briefly explained is it aims for a target, checks result, adjusts accordingly.
Closed loop idle control means a feedback loop eg ignition_adjustment = (ideal idle speed - actual idle speed) * tuning factor
Eg it is constantly adjusting the idle speed based on it's current speed by adding or subtracting both fuel and ignition.
Same with closed loop O2 feedback, it constantly adjusts the fuel at cruise to obtain stoich 14.7:1 air to fuel ratio, eg the injector pulse adjustment = (14.7 - current o2 reading) * tuning factor
The equation is more complicated than that as you actually have a PID controller with 3 tuning factors, but for discussion sake it is essentially that simple.
You can quickly see if you have a error, eg the idle is greater/less than the idle speed you want, it will then add/subtract ignition timing to slow/speed up the idle.
Open loop is where there is no feedback, it just depends on the map of ignition/fuel values, eg great for the conditions you tuned in, but as soon as you switch the A/C on or get the motor really cold/hot it doesn't work.
Edited by Rolls
Just to be clear......real closed loop idle speed control is executed through an idle speed control valve, be that a stepper motor, PWM valve, or whatever. This actually is equivalent to opening and closing the throttle a little bit.
All the ECU does is open the valve a little more if the idle speed is lower than target, and vice versa.
If you have ignition control influencing idle speed, it's kinda technically closed loop idle speed control, because the ECU is at least trying to keep the idle on target, but because the tool being used (ie advancing or retarding the ignition timing) is a bit of crude way to control idle speed, it can't necessarily guarantee good speed control.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
