you have broken into 1.5s for your 60footer which is simply incredible!
my previous r32gtr which had 320awkw (street car) & knowing that the r32 is only 1450kg which is light in comparison to the r35 (what do they weigh?), i was running MT drag radials & launching off the limiter took me to my PB @ 1.5s
...you have just about matched that with street tyres, btw u have a beautiful package (that doesn't sound right hehe)
  • Replies 167
looks like toyo 888's + volk g2's
i went out to do a 60-130mph pull and was loosing traction in 3rd and 4th with my 21" yoki advans - im going to grab a set of michelin super sports asap
grip with my yoki's has just fallen off so quickly, 2nd gear is pretty much useless in this dry cold weather
Edited by domino_z
what an awesome problem to have :)
Martin what wheel and tyre combination have you fitted in these pics?
Domino was right
Toyo R888 tyres on Volk G2 black rims, 10.5 front, 11 rear
WR600 has a black/black theme going, even has the black carbon Velo race seat and black harnesses :)
Now we have the tuning where we want it the WR600 will be back at the strip next meeting on some fresh boots to run down a 9 second pass. The Syvecs management system truly allows some amazing advances in tuning these cars, like the ability to have traction control that keeps the car totally under control in the wet, so very very different to factory :)
Yes it would be I believe Domino.
Running a 9 is no burning desire for us though, been there and done that many times with the older GTRs before and know the procedure fairly well. It will be given a go, but not as a priority if you like.
We certainly wont get involved in the US game of winding the things up till they go 9s or splatter conrods all over the track just to post a timeslip on a forum. In our opinion GTR is about much more than that. 400m times are interesting, but about 1/10th of the GTR story :)
You only have to look over @ NAGTROC to see the tranny failures and other issues, and of course 99% of them on big power mods and owners wondering why it broke LOL... Good to finally see someone with their head screwed on Re: Power modding :)
US Tuners/vendors are victims of the typical American consumer - I'm sure if they wanted to they could focus on circuit setups vs drag, but the typical American thinks bigger is better and will happily pay for it, so they're stuck competing with each other for dyno number thread glory and drag times
Edited by domino_z
And totally missing the point of GTR in the first place.....
There are much better cars for dyno racing or drag racing, just not many better actual cars though :)
We keep a lot of the stock suspension rehab. In fact this run was on - totally - stock suspension. However in the next few weeks we are integrating some roll stiffness and camber into the car with our suspension development partner Whiteline :)
Some installation shots of the WR600 MY12 Willall Racing/Whiteline suspension tweaks (note on earlier models we change the spring/damper combination as well)
Camber offset bushes installed in top arms
With the camber bushes and castor bushes in place the MY12 can deliver -3 degrees negative camber in the front end, which is preferable for fast track work, and still be dialled out for street dutires
Front roll bar stifness has been changed to stop the car kneeling over on the outside loaded tyre, which is a major contributor to the beating the GTR gives its front tyres at the track, and a major contributor to understeer
Upgraded rear bar balances the effect of the front sway bar change to keep the chassis neutral
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
