Still don't know what to do or if this is normal.
Clutch is less the 100km old
Everything I have read contradicts itself and so do the mechanics
The noise seems to be made on idle while in neutral and also when the clutch is just starting to grab.
I put it into first and slowly released the pedal and it made the noise louder just as the clutch grabbed.
The sound of it is kind of like a grinding/tinkering?
The bearing that the input shaft runs on at the front of the box, though it's unlikley it's that it is worth having a look at.
It sounds like more of a throw out bearing issue but as you said earlier it was new.
The next step is pull it apart and inspect.
Edited by Dobz
I replaced the spigot and the thrust
What's the input?
Just because the Throwout bearing is new, doesn't mean it's not stuffed.
There may have been little or no grease in the bearing, and it is failing; certainly not the first time I've heard of a brand new bearing with no grease in it.
Generally, a damaged thrust bearing will make more noise if you press lightly on the clutch pedal.
If it's happening just as the clutch plate makes contact with the flywheel, the friction plate itself might be bent, not concentric etc.
It won't fix itself if you leave it; I'd definitely be having a look in there before it does any unnecessary damage.
I was advised that flywheel bolts should be tightened to higher than factory torque settings for HD clutches..I forget what setting they were done at but it was rather extreme..
the car my clutch was in previously hadn't done this and it came loose destroying the clutch..
Thanks ARTZ I might speak to the guy who sold me the clutch and ask him about the settings.
I'm a bit sceptical about that; you risk actually stretching the bolts outside their optimum elastic deformation ability (how far they can stretch) and they can actually fatigue and loosen or break.
The ability of the bolt to stretch at a certain torque setting is what allows the bolt to reliably clamp two surfaces against one another.
If the bolts that were used in your car had already been stretched beyond their ability to recover; this could well be the reason the flywheel subsequently came loose.
Re-using flywheel bolts that have been in an engine for 100 000km+ is pretty silly anyway; they do have a hard life, and they're not that expensive.
If I remove a flywheel, I always buy a new set of bolts. It's cheap insurance in a performance application.
If the noise is present with the gearbox in neutral and clutch pedal released (clutch engaged) then it's your gearbox input shaft bearing(s) that are shagged. If it's just the release bearing, the noise should worsen/appear when the clutch pedal is depressed (clutch disengaged) and quieten/disappear once the pedal is released.
Noise is more present when the pedal is pushed to the floor.
But today I took it for a brap to see what it's like.
The clutch gives out a squeel when on boost in most gears.
I was thinking of taking it to a clutch place so they can hear the noise. Then at least I can go to the guy who provided the clutch and say what I need replaced or I can go to the guy who installed it and say what he did wrong
Get him to have a look/listen; give him the opportunity to make a judgement before going off.
Sometimes things just go wrong; it's how you/he deal with it that makes the difference. He may offer to do the removal for inspection for cheap/free; if there's an issue with the parts or the workmanship he will hopefully be fair with you.
If he goes ballistic when you broach the subject; you might be better off going elsewhere; but if he's any kind of a bloke; he should be approachable.
Kasko it's definitely clutch related, particularly as you've just installed the clutch and it's only just come about. I'm guessing thrust bearing screwed or wasn't greased properly. That or clutch wasn't alligned properly. Slight possibility is also an incorrectly installed spigot bearing/bush.
I think the new clutch was a solid investment...
Actually, it's a sprung centre.
cwhatididthar?
I wish it all just went together and I could be heading out to Sutton rd this weekend.
Looks like its just another set back and some more cash invested.
On the plus side I sorted out my idle
and am currently speaking to HSD about getting some new bushes for the coilovers
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
