I have a question to which I am yet to find a difinitive answer to (yes I have searched the forum & I have also searched on the nistune site).
I have an S2 RS4 AUTO, my question is....... is there any diference from the manual nistune board to the auto one?
If someone can shed light on this it would be appreciated.
i dont think so, pretty sure you can nistune any of the s2 ecu's
rough price on the nistune group buy? Ideal time for me to get it done as i don't drive my car till june and then won't again until november :(
If i can get 5 cars all booked in i will do them for around $900 supply fit and dyno tune. This is a $200 saving. Conditions apply
PM'd you Jez about Link as well.
And I'll let you know when my new plenum is installed > hope to see you soon. :)
The board is the same, the base image is slightly different.
i would be interested in this minus the tune as im in vic, but looking to purchase ecu very soon as im almost finished gathering parts for the stag(555cc injectors, walbro pump, HDI gt2 fmic, TD06-20g, z32afm, nismo short shifter). so im after an ecu, was going to use another PFC like i did in my skyline, but the cost is a bit high for a daily and only looking for around 250kw atw.
Very interested but I need a Full ECU as well as I have a MINES ..Maybe Jez could help on that for least me if time is right?....
Take a pic of the inside and send it to Jez - it may be that the Mines chip is on a daughterboard that will accept the Nistune chip.
Most are just a chip as u say. The aftermarket chips can be a pain to desolder sometimes but makes me earn my money haha.
For the guys interested can i get u to send me a pm with ur details on the car and mods, tune or no tune and when we get enough participants i can put the order in.
Ok Ill take a look but I have been told by power tune that MINES all ways fill the board with the glue stuff but no harm in checking as mine maybe slipped thorough :P
Other wise if anyone selling ....
    • And if it still spikes, just for now, turn off VCT completely by disabling it OR simply unplug the solenoid. Just to rule out excessive exhaust pressure. I recall a video from Motive DVD about a decade ago, where Hawkins original single Garrett GTX3582 or so turbo had boost control issues sub 1.4bar of boost as well.   Food for thought? Is there anyway you can peg the WG completely open and/or dodgily not plumb it back into your exhaust system for testing purposes?
    • I will endeavour to give it a crack sooner or later. I have the wastegate apart at the moment so I'll replace it with a smaller spring just to see what it does and if I have to go back then so be it.   If it spikes to 23 but can then be controlled back to 20, then the gate must not be 100% open... So if it's not 100% open then why can't it drop the boost even further than 20psi (I understand it's not linear). What a headache this whole thing is.
    • Either the WG is reaching full opening, or it is not. The "it is not" case could only occur if there was not enough time available to swing the valve fully open during that boost event. I would consider that to be unlikely, as this is a commercial product that is in use elsewhere, so it really should work. But in your case, because there is definitely SOMETHING wrong, it should not be assumed that things like that are working as they should. You should put a video camera where it can see the actuator (if at all possible) during a run to see how far it is moving.
    • I think you're mostly on the ball there. With the straight gate, I suspect the weight of the spring will determine how quickly the gate can close, when not run with active pressure drive on both sides of the diaphragm. Otherwise, with drive on both sides of the diaphragm, you could almost go without a spring at all, only needing one to make sure that the thing was actually closed while completely off boost and not having pressure available to drive it closed. Butterfly valves have mostly symmetric loading when there is flow going through them, meaning that the gas hitting the upstream part of the blade is balanced by the gas hitting the downstream part of the blade, which means you don't need actuator torque to overcome any non-symmetric flow induced loads. But the gas flow does impart a purely normal load against the shaft, which transfers into the bush/bearing at each end of the shaft and does increase the torque required to make the shaft turn. Only a little, but it is there. I have no feeling for the amount of force involved in a WG application, but it certainly could make an argument for a decent spring weight being required. But all of this is just peripheral to the actual problem here.
    • The answer to this would be I followed the documentation from Turbosmart which said each spring pressure could achieve a maximum of 5x it's rated pressure so the included smallest spring being the 6psi had a range up to 30psi. I went with the 12 because I figured it'd likely hover around 15psi as a base pressure however I was obviously wrong.    I have a log here that I'll dig out that is purely wastegate and no Mac valve controlling anything.   If it can't hold anywhere near 12psi, does that mean the straight gate is virtually wide open during a run? Or am I thinking about this all wrong.   I could Tee Piece into the cooler pipe pre intercooler where the wastegate gets its feed, and send that to the ecu and see how that reads, I just don't have a spare pressure sensor currently that's all.
