g'day
iv got a t66 with a 1.07 front and 1.0 rear housing on a 6boost manifold that im planning on putting on a standard 25 with a greddy plenum and 600cc injectors. how much power should i expect out of the setup? how much boost should it safely handle and will it be very lagy?
cheers
https://www.sau.com.au/forums/topic/400088-t66-on-rb25/
Unless its a chinese knock off, which often do not follow any real naming conventions (ie, T70s with 61mm compressor inducers) the T-series use compressor inducer size in mm as an identified, ie - T61 = 61mm inducer, T66 = 66, and so on. It'd most likely be a Garrett or Turbonetics (who have been price cutting lately, they'd only be able to sell behind the times turbos for a premium for so long) turbo.
The short of it, it will be big old school truck spec wheels rated to in the area of 700hp and likely to have plain bearings. T67s are the ones which coincide with GReddy naming, the Garrett T67 (aka T04R) are a pretty big stick compared to the GReddy T67.
https://www.sau.com.au/forums/topic/400088-t66-on-rb25/#findComment-6355893
and not to mention if everything else isn't up to scratch it will affect the power output greatly, eg air leaks, exhaust, tuner, slipping clutch/trans.
Cheap and big power don't go together, I'd sell the turbo and by something more sensible especially if it is a street car, it won't even feel fast on the street, just lag lag lag lag lag boost limiter.
https://www.sau.com.au/forums/topic/400088-t66-on-rb25/#findComment-6357155
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
