  • Replies 104
Oh hey guise :action-smiley-069:
Just a suggestion but the tuner could have set rev limit to hard cut at 2000 which would have made it easier to diagnose
They may have done this, I'm not sure how they found it in the end, I went in to give them a hand on Friday and they had already found the problem and sorted it out. Just kept me in the dark about it, they must like suspense almost as much as me ;)
I'll post pictures hopefully later today guys, pictures are worth a thousand words...
Well... Sort of. Not really. I can't for the life of me understand what happened. I certainly didn't do it. But I can't see how my workshop would have done it either.
Will make more sense when I post photos. Which I can't do yet because I haven't got the car back yet :glare:
Explain the hole. Could this have damaged a valve or stick a valve open?
Possibly, I imagine when you shatter a cast alloy manifold like that there will be some debris. But I don't know which cylinder the valve problem is on, if it is only cylinder 1 then I imagine the shattered manifold was the cause.
I'm just waiting for my tuner to add up how much I owe them and then I'm going in to get the car home, so I'll post photos in a few hours.
IE could it have created debris that the motor could have ingested on its maiden limiter bash?
Again, quite possible. Thing is, I would expect that shards of cast alloy getting stuck in the valve guides would cause more of a permanent problem than just on full load power runs, ie. bent valves?
Edited by Hanaldo
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
