I'm getting reversion with my stock bov as I am running a highflowed rb20 turbo on an rb25 and it makes a lot of boost quite early, eg 6psi by 1900rpm in 4th.
If I boost with minimal throttle and back off I get a odd fluttering noise from the intercooler piping, but not the same as flutter from running no bov, it actually comes from the pipes/intake on the right hand side instead of the pod.
Anyway this means if I get on boost with the throttle just cracked open and then throttle off to change gear it fuels up and means the throttle doesn't work for about half a second, this makes for clunky gear changes which is quite frustrating.
I'm getting the tune touched up on thursday and Im hoping we can tune a lot of this out but is there anyway to make the stock bov work better? It doesn't flutter when I back off but I'm getting all the side effects of reversion, eg the maf signal flaps around, fuels up and pops on gear changes now and then.
The way Nissan get around it is to drill a small (4mm) bypass hole in the bov. Does yours have one?
Are you running the stock intake? The angle of the bov return can have a lot to do with it.
It is the stock BOV, is it there from factory?
I am running a metal intake but the angle looks identical to stock, plus I had a very similar issue with the rubber intake.
I don't know, I have the hole on mine and when I block the hole it can act like you mentioned.
The intake is the key, the stock bov return is on a crappy angle, it needs to point toward the compressor. If any air goes back up the intake the afm voltage will drop causing what you described.
Yep pretty much that was the problem.
The metal intake pipe I have with the old silicon joiner looks identical to the stock bendy hose, it was just about ~10cm shorter, so the AFM was mounted a lot closer to the bov outlet than it should have been.
Will grab a picture of afterwards tomorrow if I have time.
edit: Oh the new hose has a ~90 degree bend in it as well, probably makes more difference than just having it longer as well.
Edited by Rolls
That would definitely help with the reversion but I hope you aren't chasing big power. The silicone 3 inch bends can suck closed at less power than the stock rubber ones, mainly due to the intake being so close to the exhaust manifold.
sorry for hijacking but just wondering if it matters how short the intake pipe is if you don't run a blow off valve / have an aftermaket one?
I'm getting a metal intake pipe made up just wanted to know if i can get it made shorter then the stock ruber one.
Thanks
I do have a bov (aftermarket), I was just saying in general aftermarket/no bov as theres no need for the return
I was thinking of just getting a copy of the stock rubber one but wanted to know if i could go shorter.
Thanks
Edited by Autumn33
I have read all the threads on atmo bov's but i have none of the problems stated in the theads, only trouble i had was my aac valve just had a breather on it for some reason, now all sorted & is running perfect.
I'll just get a direct copy of the rubber one.
Thanks
Thanks
Perhaps you need a wideband to know how rich the engine is running at light loads and decel. All the cars with atmo's I see, the rear bar is covered in soot, the cats have collapsed and fuel economy is woeful. You can tune around it to some extent I guess, perhaps your tuner is a gun...
I make a direct copy if you have trouble finding someone local to make one.
I am running a metal intake, it is just the bit that joins on the pod that is silicon, seems fine with 260kw where as the stock pipe used to suck closed on less than 200kw
Thanks though, will keep an eye out
If you are running no BOV at all the longer the intake the less bad the reversion will be as it will be buffered over a long time, you will still get it, it just might not be bad enough to stall the motor.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
