L O L I liked the part about "Honestly you should be happy that they actually have the correct equipment and actually heard the detonation."
and "especially when you have allocated 5 hours for a tune..... and not 2 days"
Who could possibly take 2 days to tune a car? Imagine the bill, hi yes that will be 1600$ please oh and great news it made 6kw more!
Not sure if you're serious or taking the piss but you'd be extremely surprised how many tuners DO NOT use knock detection on their dyno. I know of at least 4 in the greater Brisbane area and not only don't use it, but when challenged about it, simply state how good they are they are able to detect knock without the need for a knock detection device.
I can tell you I was very surprised when I also thought I had a good ear for that sort of thing then someone put a headset on me and proceeded to pull 8 degrees of timing out before I could stop hearing it knock. The car made 10rwkw less after that. The customer didn't blow it up.
  • Replies 77
Posted Images
I always use knock detectors, even if the ecu has it, its hard to hear knock on certain cars over the engine noise and ecu's arnt always accurate, especially vipecs would read huge knock when there was none and read low knock when I could hear it quite clearly. I know a lot don't use them because half the time there to lazy to clip it on the block or there works to cheap to buy one, also yes a lot of cars can take time on the dyno to sort out bugs, but not something as simple as det.
I also know of a big name workshop here in Adelaide that doesn't use knock detection, I won't ever be getting my car tuned there again as when I hooked up some knock ears and reved out 3rd on a warm day it was detonating like crazy.
Really really slack, PM if you want to know who.
UPDATE:
Picking car up tommorow afternoon, if I have time I will post a dyno sheet.
But because I was only sent an 8psi actuator it didnt make a whole lot of power. I'm just glad they fixed the detonation and got it running correctly.
Needs a new rear muffler though, its partially collapsed.
I dunno how these things handle det like that. I freak with the slightest little bit of det and dont push through it.
how accurate is a pwr fc at detecting real knock? or are all computers about the same
I have found they are all different. Some actaully ping at around 35. And some ping after 60.
So without listening and knowing, be carefull
Jez , your knock detection setup is pretty cool and seems to work quite well, not to mention it was probably cheap as. But ill admit at first I had no idea what the hell it was ...
Edited by Mitcho_7
Haha cheers man,iproblem is i spent $900 on the kmon kit and i prefer my new setup as i can hear alot more
Good power but f**k its lean, 12.5:1 =/ no wonder it was pinging lol
I run my own cars at 12.5:1.. never had an issue..... especially as the boost is so low... could go easy 13 depending on engine
I had mine at 12.5:1 pm 19psi dropping to 16 psi making 260kw on a highflowed rb20 turbo on a neo, it also didn't ping which is suprising considering how small the rear housing is.
we detuned to 11.5-12 for safety but you can get away with it if timing is conservative.
What is your new setup?
Its top secret :)
Maybe i should start tuning lean... Seems no body has been melting motors
Its top secret :)
It is a street car, I would be nervous running it above 11.5:1 on the track, though I would be dropping the boost level for safety as well.
What are your thoughts on lean + less timing vs rich + more timing? I've heard the japs don't even use AFR they just use exhaust temp and go rich as hell and smash the timing into the motors.
Is your secret method a garden hose? Ear muffs with a microphone wrapped in a rag? cmon spill.
Wow, ile show you a pic of my SR20's piston when I tuned it to 12.5:1, half the side of the piston melted lol was at 18pound though. I'd never tune above 12:1 now.
Edited by 51NNA
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
