IM PARTING OUT MY 1994 R32 GTR , CLUSTER SHOWS 62000KMS
MOTOR HAS BEEN SOLD
Apexi power intake pipes with apexi filters and z32's with plugs $450
Gearbox pull type being 94 model $600ono
Hks oil filter relocater and oil cooler all hoses $450
Rear diff and half shafts $500
Front bar reinforcement $120
Seats front and rear the front seats need retrim but besides that all good with rails $400
Alternator $100 , Starter motor $80 Ac compressor $80 , power steer pump $80
Bootlid with wing in white has a dent or two nothing major $150 ono
Front and rear calipers and discs and braided lines $550 ono
Front cv shafts $200 for both ono
rear tail shaft $120 ono
front pipes 2.5 inch to 3 inch at cat slight scratches from speed bumps $80
3.5 inch cat back one muffler and cannon great sound $450 ono
Heaps still left pm for prices and availability
IN SYDNEY WESTERN SUBURBS PICK UP ONLY
PRICES MAYBE NEGOTIABLE - NO LOW BALLERS PLEASE
Forgot still have front and rear subframes
Hubs abs sensors tail lights
Master cylinder and booster
Clutch master and booster
Abs module fuel tank
Pm for info
Front reo sold, front bar sold , guards sold
Headlights sold , engine sold , grill sold ,
Wheels sold
Inter cooler that's up has some bent fins and some bugs but no leaks 4 inch thick 150 pick up
If your chasing something do your 32 pm me
Also has adjustable coilovers
Will have brand and pics up by tomorrow
Interested in the coil overs if you can let us know what brand, specs etc.
Coil overs sold , fuel sender sold
Fuel pump still available 50 bucks
Fuel tank 80 bucks with straps
Full brake set 450 Calipers discs front and rear
Brake master cylinder and booster 150
Clutch master cylinder booster and hydraulic pipes 150
Abs module 100 bucks
Rhf plastic guard liner complete 50 bucks
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
