Hey guys.
I found a R32 GTS4 for sale with a RB25 from a stagea making ~350rwhp.
I have a few questions:
1. Does a GTS4 run the same gearbox and front axles etc as a GTR?
2. Where is the HICAS pump and reservoir, in the boot on the right side?
3. Is the rear diff the same in a GTS4 to a GTR? Ratio, strength, LSD?
4. Where is the ATTESA system ECU? Wiring and controlling components?
5. How does ATTESA system work, does it only send power to the front wheel when the rears start to slip? What is ETS?
6. How do you know if the system still works, like if fuse is blown or wiring is dodgy how can you tell? Does the gauge that says front torque split only read something if the system works?
7. Where is the high pressure pump that makes the front wheels engage power?
8. Is it common for 4th gear to crunch in GTS4 or GTR gearbox?
9. Is it worth putting in a GTR rear end in a RB25'd R32 GTS4, what are the advantages?
10. If ABS has been removed, does it change how the ATTESA system works?
11. Anything else you can tell me that could be useful.
Thank you all in advance.
https://www.sau.com.au/forums/topic/401133-help-needed-from-r32-gts4-experts/
1. The gearbox is essentially the same. I don't know about the ratios, but they are swappable. I am pretty sure that the ATESSA system on the GTS4 is not as clever as the GTR's though.
2. HICAS is 4 wheel steering. As such, it is no different on a GTS4 than on any other R32. The reservoir is the power steering reservoir.
If, however, you mean ATTESSA reservoir, then yes, it's in the boot.
3. No. Diff is same as GTSt. that includes 5 bolt driveshafts and normal uni joint tailshaft, rather than GTR's CV type tailshaft and 6 bolt driveshafts.
4. Under the parcel shelf. Not the HICAS computer which is also there.
5. Google it.
6. Depends on how well the retrofit has been done, with respect to wiring and so on.
7. Not sure.
8. Shouldn't be.
9. Nup.
10. Dunno. Possibly.
5. Google it.
7. Not sure.
8. Shouldn't be.
9. Nup.
for the r32 gts4 the hubs(spline), half shafts, diff and tails shaft are all to suit/swap-able with a gtr
much like the gearbox i'd say the ratio is different tho
Probably not as strong as a GT-R, but can't say for sure. After all, it's only designed to handle a RB20DET.
HICAS pump / reservoir is the same as the P/S pump /reservoir. R32 HICAS system is hydraulic, later models are electric.
The reservoir in the boot is the ATTESSA fluid reservoir.
Both are R200 diffs. There the similarities end. GTS4 is a viscous LSD, 4.375 ratio. GT-R is a mechanical LSD, 4.111 ratio. (Stagea, as in mine, is 4.083, open?)
In the boot, under the rear parcel shelf. Inputs come from:
ABS wheel sensors (wheel slip)
Throttle
G-sensors located under the centre console
see 4. Also, search this site.
Warning light in the dash will come on in any sort of error condition.
From memory, it hangs off the rear diff
Not normally, not in my case. Possibly a sign of a mistreated box.
I haven't done anything like that in mine, which was dynoed to 180kW at all four.
Depends. If you leave the ABS sensors, then ATTESSA should still work.
The advantage of putting a GTR rear end would be a proper mechanical LSD. It would be 4.1:1 (higher geared) so that could be a good or a bad thing... and the disadvantage would be that you would need to change the front diff to a 4.1:1 as well.
Thanks heaps for the heads up guys. I used the F* out of google images and I now sorta get whats going on with Attesa (4th year engineering student btw)
A: Do GTR's have ATTESSA-ETS, the more advanced version?
B: Which ecu under parcel shelf is Attesa and which is Hicas?
C: Do the attesa systems mess up much?
D: If you have a 300+rwhp GTS4 and you pull the 4wd fuse, will it wheelspin in 2nd when coming onto boost? And have way more traction if attessa works?
Cheers again
A. http://en.wikipedia.org/wiki/ATTESA-ETS
B. Looks like http://i106.photobucket.com/albums/m263/bades13/IMG_4194.jpg and http://i106.photobucket.com/albums/m263/bades13/IMG_4195.jpg
HICAS has two plugs like http://i106.photobucket.com/albums/m263/bades13/IMG_4196.jpg
Side by side..... http://i106.photobucket.com/albums/m263/bades13/IMG_4199.jpg
C. They have their failures. Poor maintenance is the main killer.
D. I'd be upset if you couldn't spin it up changing into 3rd, and like of course it will have more traction in AWD.
  • 1 month later...
gts4 and gtr have the SAME gearbox as i have opened both side by side. your 4th gear is crunching cause your box has either been flogged or poorly maintained or both, as there are 3 small stainless clips in the synchro of 4th gear to allow it too work, albeit it a poor design and no nissan doesn't make them anymore, get a re coed box for like 800 somewhere or get and r33 gtr s2 box that can handle like 700hp. the awd system is hydraulic the front wheels will grip once the system realizes there is slip in the rear, you can hook up a kill switch to the fuse to alternate between 2wd and awd for some fun and it doesn't cause any issues, just make sure to stop before switching it over, also with these cars and other gtrs, wrx, evos, etc make sure that all 4 tyres share the same profile and rim size as having different sizes can and eventually will destroy your diffs. there is no need to change the diff out off a gts4 they are strong as and have seen 9 sec pass on many cars from japan, just look after it they are also known to handle 800hp plus with the right care and driving style. the cars are beautiful i will never sell mine i just spend 20k on the engine now is rb30. also your front suspension is GTST NOT GTR don't let people tell you it is because the strut end has a different fitting. also be careful replacing the ecu with another r32 ecu the gts4 has a fit if you put in a gtst not a gts4 one, f**ks me why. Honestly i would ditch the rb25 and get an rb26, if i where in your shoes and not have the money i did to throw at this thing. any other advise i can think of with these cars i will send your way when i can.
  • 2 months later...
Thanks for the replies guys. It really helped with my car.
I have a new question about GTS4's.
> Does the R32 GTR diff fit straight into a GTS4? Front and Rear, or are the housings difference size/shape/bolt pattern?
> Are the diff ratio's different?
> Are R32 GTR diffs the same ratio, like all only 4.1?
>If my rear diff in GTS4 has loads of backlash and I want to put in a better one, should I just get a 1.5 or 2 way LSD with correct diff ratio to match for rear. Rather than getting R32 GTR front and rear diffs as front diff install is engine out job.
Edited by reNEGaDe88
  • 4 months later...
No-one ever (correctly) said that GTS4 have GTR suspension. What they do have is GTR front and GTSt rear.
Other way round - rears are the same as GT-R. It appears that all models have the same style fronts.
I found if you ask for GT-R suspension components, you get the right stuff for the GTS4 (at least in R32s).
  • 3 months later...
>>>>>>>>>NEW QUESTION:
Will a R32 GTR front sway bar fit a R32 GTS4?
Found this thread: http://www.skylinesaustralia.com/forums/topic/283424-gtr-r32-front-sway-bars-suit-what-other-vehicles/
Though I unbolted the GTS4 one and put it next to a GTR one and the GTR one bends out 40mm on each side, so it doesnt look like it will fit.
Any ideas?
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
