Hey guys,
I really would like to know what are the Garrett equivalent of the HKS GT-SS turbo's?
I have researched for a bit to find many mixed results that they could be either the -7's or -9's
based on the source. However, from my understanding the -7's are actually closer to the
N1 turbo's off the R34 GTR's.
Also, does anyone which is suppose to output more power between the -7 and -9's?
Thank you.
https://www.sau.com.au/forums/topic/401421-garrett-equivalent-of-hks-gt-ss/
GTSS is EXACTLY the same as -9. It's the same part without a pretty badge. This information is in just about every thread started on this topic since SAU started.
For the rest, use the search button. It's been covered so many times, in great detail. There won't be a single question you can think of that hasn't been answered already on those turbos.
There's a 300kw GTR thread, 400kw thread, RB26 dyno results thread, 7's vs 9's thread (not this one) plus more. There's ECU threads, Fuel system threads, exhaust threads, dump pipe threads, intercooler threads, air box threads, clutch threads, radiator threads, brake threads, wheel size and fitment threads. It's all been covered before :)
This may seem rude, but members on here who have taken the time to give very detailed answers and information in the past will find it rude that their past contributions are neglected by other users who are too lazy to take the small amount of time to search when they've given their time to answer the questions already.
Le sigh.....
Will -9's (GT-SS) go well with a 2.8??? :P
No one has asked that yet!
My guess is awesome low to midrange, then a choked top end and drop off after 6500ish due to smaller hotside compared to -5's, and smaller cold side witth more heat if you put in more PSI.
Le sigh.....
+1
....but, They will make more hp than the -7 due to the larger trim on the comp. And a -5 might be too big for him
gtr.uk confussed me so much mate, there quite old posts aswell but people keep saying gtss are -7s ect ect, or they say -7 is bigger then -9 ect ect
The pommie forum has really taken a dive in quality over the lasts few years.
-9's are SS's without actuators and a badge.
The difference between HKS GT-SS and -9's is nothing. GT-SS used to come with HKS stamped front compressors but now they have the same cover as Garrett -9s (and have had it for ages now). GT-SS come with adjustable actuators, -9's don't come with any actuators (Garrett do make bolton adjustable actuators to suit though that can be brought seperately).. although if you wanted standard actuators on -9s then you would want "-1's". For more info: https://www.turbobyg...oductCd=GT2859R
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
