Update...
Driver and passenger seatbelts - $35 Drivers side SOLD, Passenger $15
Rear wiper with motor - $5 SOLD
Hood lining with interior lights and sun visors - $50 Can separate. Sun visors sold. $30 for the lining and lights.
Centre console with decent hand brake cover - $40
Glove box - $25
Door trims both sides - Available again. $40ea or $60 for both
Rear seat side trims - $20 for both SOLD
Heater, A/C, fan unit. (under dash). Has had the A/C lines chopped but heater core and fan are good. - $50 can sell just the bits you want.
A pillar trims - $10
Climate control module - SOLD
Adding the rear quarter window trims. $40 for both.
also still got driver side kick panel. $15
How Upto date is this list and are u able to bring stuff to Sydney for WTAC?
Edited by krayzie32
  • Replies 66
Posted Images
That is up to date. Happy to bring things up to WTAC at Eastern Creek. Let me know before wednesday 8th as I'll be coming up that day.
  • 3 weeks later...
Hey mate, would ya have the rear 1/4 window trims?
Yeah mate. Pretty sure I've still got them. Reasonable condition but they're not 100% so $40 for both.
  • 3 weeks later...
  • 1 month later...
Still parts available. Give me some offers, not really chasing money, just trying to clear these parts to someone that needs them.
Hey man, you got any dash vents? My bogan mate put his feet up on the dash and busted my vent. You got any vents?
Cheers.
P.S please let me know if you have any dash vents. Thanks.
Hey was wondering if when the a/c was in the car was it working. If so can i grab the tx valve out of it.
Cheers.
You'll have to elaborate on what that is. A/C has been out of the car for like 5 years but might still have it. It did work.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
