Update...
Driver and passenger seatbelts - $35 Drivers side SOLD, Passenger $15
Rear wiper with motor - $5 SOLD
Hood lining with interior lights and sun visors - $50 Can separate. Sun visors sold. $30 for the lining and lights.
Centre console with decent hand brake cover - $40
Glove box - $25
Door trims both sides - Available again. $40ea or $60 for both
Rear seat side trims - $20 for both SOLD
Heater, A/C, fan unit. (under dash). Has had the A/C lines chopped but heater core and fan are good. - $50 can sell just the bits you want.
A pillar trims - $10
Climate control module - SOLD
Adding the rear quarter window trims. $40 for both.
also still got driver side kick panel. $15
How Upto date is this list and are u able to bring stuff to Sydney for WTAC?
Edited by krayzie32
  • Replies 66
Posted Images
That is up to date. Happy to bring things up to WTAC at Eastern Creek. Let me know before wednesday 8th as I'll be coming up that day.
  • 3 weeks later...
Hey mate, would ya have the rear 1/4 window trims?
Yeah mate. Pretty sure I've still got them. Reasonable condition but they're not 100% so $40 for both.
  • 3 weeks later...
  • 1 month later...
Still parts available. Give me some offers, not really chasing money, just trying to clear these parts to someone that needs them.
Hey man, you got any dash vents? My bogan mate put his feet up on the dash and busted my vent. You got any vents?
Cheers.
P.S please let me know if you have any dash vents. Thanks.
Hey was wondering if when the a/c was in the car was it working. If so can i grab the tx valve out of it.
Cheers.
You'll have to elaborate on what that is. A/C has been out of the car for like 5 years but might still have it. It did work.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
