Having a few issues with the the car when on the road in any gear if it hits .5 bar the engine cuts very smooth cut, no struggling no missing just bam that it nothing. untill your fully off the accelerator then it comes back to life, you can have the throttle 3/4 open and will rev to limiter.
history of things i have tried,
removed all turbo side replaced all gaskets lines that looked bad and clamps.
replaced TPS and AFM
removed factory boost solinoid and run manifold pressure to wastgate
removed all cooler piping and replaced some clamps all ok
changed plugs gap .8
running out of ideas?
https://www.sau.com.au/forums/topic/401653-r33-gtst-boost-issues-05-bar-cut/
stock ecu on it, have an apexi boost gauge i have just connected for testing. makes boost ok but at about 6k its creeps up slowly from .45 bar and when it hits the .5 it cuts.
That was my first thoughts it was hitting the boost cut but my understanding thats at 1.2bar?
There is no "boost cut" on Nissan ECUs (alright, on the Neo, which actually has a MAP sensor connected to the ECU, there is a boost cut). But certainly not a boost cut on R33 ECUs.
What you DO have is a load based cut. When the ECU calculates a TP value (based pretty much just on AFM reading) which is too high, you get a cut. This can actually happen at a whole different range of boost levels, depending on how much other modification the car has (exhaust, bigger cooler, etc) and the weather, etc.
What I would suspect is that the boost gauge you are using might not be accurate, and somehow you have more boost than you think you do. Consider this one unlikely. Or you have a big boost leak that you haven't found, leading to high air flow at the correct boost in plenum. Or you have a faulty AFM.
Ok changed a few bits has made it abit better.
Timing was set on 0deg so set cas to 15deg.
Factory boost gauge sensor was missing so grabbed one of another wreak out back now factory cluster works only goes halfway up won't go to the 7, which should be correct for 7psi.
Have connected factory boost solinoid.
Seems to get to 6500rpm now then cut.
Can't be afm as I have changed that.
But have noticed there is a beep from the ecu when it hits the cut?
limiter is at 7200
And I know the factory gauge 7 on it is about 14psi that what I said it only goes to half which would mean its running 7pis = .5 bar or there abouts.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
