Nismo solid shifter
nismo steel braided clutch hose
nismo Gt titanium gearknob
nismo panel filter
nismo front/side indicator's.. hate the look of the imitations
post-69990-0-53012400-1339481559_thumb.jpg post-69990-0-32370700-1339482345_thumb.jpg
only problem is how freaking cold the gearknob gets in winter :P had a nismo cluster too but dumbass auto elec dmgd it :/
yes that front badge is cheapo ebay replica. Does Nismo make front badges?
only negative thing i can say about nismo is the $1200 for rear tail-lights.. c'mon is it just me?
haha nope not just you, thats why I made my own copies..
sorry to hijack :P
nismo parts in my car..
Nismo Rad Cap
Nismo clutch and brake lines (replaed by customs when going bigger rotor)
Nismo gearknob
Nismo GTR front bar
former nismo items,
nismo cluster
oil filler cap
suspension arms
seen a thread on how to make those, looked all nice until it got to the part where he had to make some sort of silicon base or something, then i'm like damnit, don't know how to do that :/
This ?
genuine? where can i get?
my old GTT :wub:
just cosmetic stuff
genuine nismo rear bar, none of that Altia crap they flog off as 'nismo'
:whistling: lol if it wasn't fiberglass i would've gone for it. not a fan of fiberglass at all though, but this is nismo so i guess there's an exception.. looks nice :thumbsup:
Just remembered I had a Nismo leather shift knob on one of my previous 34's.
Was a lot friendlier than my old titanium Nismo knob, after the car had been out in the sun for a while. Also didnt show the fingerprints.
Edited by iwanta34gtr
no way this wasn't fibreglass, or were you referring to altia bars? genuine nismo are made from the same plastic as stock bumpers, came with the car when I bought it :cheers:
It was definitely fiberglass. I've had two of these and still have one that I can't use on my car (wide guards).
So if anyone wants genuine nismo GT/T rear bar, its in the for sale section :)
Small knob.
This is my one too :) good feeling ontop of my c's short.
wow ok never knew that hehe, like I said mine came with my car when I bought it as a fresh import, I was reading somewhere ages ago that these were plastic.
The altia ones are plastic.
All good :) I always hoped factory nismo gear was plastic for durability, but I guess not, some of their kits i've seen (350z and some other pieces) were also fiberglass. But then they also do a lot of their gear in plastic as well.
yeh altia is plastic, got it on mine. and as far as i know and with some confirmation with EZY34 the nismo 1's are definately fibreglass, but like i said, it's nismo so it's not exactly cheapo fiberglass that cracks easy and leaves a really shit finish when painted.
i think the gtr z-tune front bar is in some way fiberglass too (CRFP: caron fibre reinforced polymer)? some say the "polymer" refers to it being glass fibers.. is that wrong?
Understand it is genuine but wouldn't mind confirmation from some one on here.
Advertised as
Nissan Nismo Emblem Badge Nameplate Decal Rare JDM Tuning
  • Approx. (Width) 4.33" inches x (Height) .55" inches. Quick and easy installation!
  • Not a cheap Vinyl or Decal Emblem. Made with Special Aluminum Emblem and Embossed to create a 3 Dimensional surface.
  • Aircraft quality Aluminum. 100% Brand New
  • Hard Anodized in Color for a Long Lasting Finish. High Quality Emblem
  • Comes with 3M self-adhesive backing. Ready to stick on ANY flat surface
$9 ea ???
definately fake. + i would need something that screws on, it's gona sit on mesh. i've seen 1 thats exactly the same as that, probably from the same guy which screws on but yeh deinfately fake. wash your car enough and the red will start to discolour. they all say high quality but even the 1 i have on know is peeling abit..
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
