Nismo solid shifter
nismo steel braided clutch hose
nismo Gt titanium gearknob
nismo panel filter
nismo front/side indicator's.. hate the look of the imitations
post-69990-0-53012400-1339481559_thumb.jpg post-69990-0-32370700-1339482345_thumb.jpg
only problem is how freaking cold the gearknob gets in winter :P had a nismo cluster too but dumbass auto elec dmgd it :/
yes that front badge is cheapo ebay replica. Does Nismo make front badges?
only negative thing i can say about nismo is the $1200 for rear tail-lights.. c'mon is it just me?
haha nope not just you, thats why I made my own copies..
sorry to hijack :P
nismo parts in my car..
Nismo Rad Cap
Nismo clutch and brake lines (replaed by customs when going bigger rotor)
Nismo gearknob
Nismo GTR front bar
former nismo items,
nismo cluster
oil filler cap
suspension arms
seen a thread on how to make those, looked all nice until it got to the part where he had to make some sort of silicon base or something, then i'm like damnit, don't know how to do that :/
This ?
genuine? where can i get?
my old GTT :wub:
just cosmetic stuff
genuine nismo rear bar, none of that Altia crap they flog off as 'nismo'
:whistling: lol if it wasn't fiberglass i would've gone for it. not a fan of fiberglass at all though, but this is nismo so i guess there's an exception.. looks nice :thumbsup:
Just remembered I had a Nismo leather shift knob on one of my previous 34's.
Was a lot friendlier than my old titanium Nismo knob, after the car had been out in the sun for a while. Also didnt show the fingerprints.
Edited by iwanta34gtr
no way this wasn't fibreglass, or were you referring to altia bars? genuine nismo are made from the same plastic as stock bumpers, came with the car when I bought it :cheers:
It was definitely fiberglass. I've had two of these and still have one that I can't use on my car (wide guards).
So if anyone wants genuine nismo GT/T rear bar, its in the for sale section :)
Small knob.
This is my one too :) good feeling ontop of my c's short.
wow ok never knew that hehe, like I said mine came with my car when I bought it as a fresh import, I was reading somewhere ages ago that these were plastic.
The altia ones are plastic.
All good :) I always hoped factory nismo gear was plastic for durability, but I guess not, some of their kits i've seen (350z and some other pieces) were also fiberglass. But then they also do a lot of their gear in plastic as well.
yeh altia is plastic, got it on mine. and as far as i know and with some confirmation with EZY34 the nismo 1's are definately fibreglass, but like i said, it's nismo so it's not exactly cheapo fiberglass that cracks easy and leaves a really shit finish when painted.
i think the gtr z-tune front bar is in some way fiberglass too (CRFP: caron fibre reinforced polymer)? some say the "polymer" refers to it being glass fibers.. is that wrong?
Understand it is genuine but wouldn't mind confirmation from some one on here.
Advertised as
Nissan Nismo Emblem Badge Nameplate Decal Rare JDM Tuning
  • Approx. (Width) 4.33" inches x (Height) .55" inches. Quick and easy installation!
  • Not a cheap Vinyl or Decal Emblem. Made with Special Aluminum Emblem and Embossed to create a 3 Dimensional surface.
  • Aircraft quality Aluminum. 100% Brand New
  • Hard Anodized in Color for a Long Lasting Finish. High Quality Emblem
  • Comes with 3M self-adhesive backing. Ready to stick on ANY flat surface
$9 ea ???
definately fake. + i would need something that screws on, it's gona sit on mesh. i've seen 1 thats exactly the same as that, probably from the same guy which screws on but yeh deinfately fake. wash your car enough and the red will start to discolour. they all say high quality but even the 1 i have on know is peeling abit..
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
