Yes, it's embossed Simon in the modern day n-i-s-m-o logo on the other side.
Part# KWA10-50710 (more fancy and detailed than KWA10-50720)
I've sent Marko to you about your LMGT1 set.
Look after him won't you?
Meanwhile, I don't know what this old school font is called but for my R32 GT-R, I'm collecting them...
I'm after the radiator cap one (if anyone has one f/s), and I think I need to sift through this thread again too...
  • Like 1
I saw an old nismo radiator cap at Nisswreck today in SA. Although its not to the condition that you would like.
Brad,
I'm about to get some of the old style high-temp-resistant stickers made up for those rad caps.
They degraded pretty badly over time - heat cycles.
Once made, I can show you how it (the replica) looks and whether or not it's for sale.
I would only sell it to a person with a 1.2-1.3 pressure rad cap anyway; and would take no responsibility for how the buyer's rad cap behaves.
Can anyone tell me anything about these shocks? Came out of my r32 gtr but i dont think they are the factory shocks are they? They look as old as the car though. Nismo part numbers 56110-rn585 and 56210-rn585. They are made by KYB.
post-72069-0-82900600-1412072908_thumb.jpgpost-72069-0-39379800-1412072925_thumb.jpgpost-72069-0-97168000-1412072951_thumb.jpg
They felt quite firm but i cant compare them to standard gtr shocks as i wouldnt know how the standard ones are, they almost seemed firmer than the BC BR's i replaced them with though. yeah ive got no idea how old they are but im sure they dont ride the same as they did when new.
Parts -
Nismo front bar
Nismo side skirts and rear under spoiler
Nismo pillar garnish
Nismo carbon wing blade
Nismo titanium shift knob
Nismo LM-GT mag wheels 18x10+20(the only size and offset manufactured)
Nismo diffuser fin set
post-135234-0-39095900-1412570099_thumb.jpgpost-135234-0-79905500-1412570169_thumb.jpg
Edited by NURVOUS
  • Like 2
I have similar suspicions, I'm a big fan of the gt500 edition though in both black and anodised.
Thanks
I suspect those magnesium wheels even weigh less than my LMGT4 GT500 18x9.5
Congrats Bueller.
Happy to weigh my GT500 if you Bueller is willing too next time the tyres are off :)
I do believe they are lighter even at 18x10 +20
Yeah for sure, as it's still wearing the original factory delivered tyres from 2002 it could be a while off though....
  • Like 1
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
