Ok, update.
I've received some payments, so thanks very much to those of you who forwarded so quickly. :thumbsup:
I'm currently painting (and trying to dry in cold conditions :rant:), so we should be on track for a mid week post run. This will hopefully see everyone braced up by the weekend, or very early next week.
Thanks again for your support, and if anyone else would like one; I'm planning another run in around 2 weeks.
You can already get the Freeway Dolphin ones, and they do stiffen up the front quite substantially, but if you plan on running a plenum spacer there isn't anything available.
If you were going to get something, you'd have to get it to go behind the plenum. There's a little bit of room back there, but not sure if you could design something stiff enough with that many bends?
hey dale,
Totally off topic but how bout underbonnet strut brace. Would you be doing one or a group buy of these in the future?? If so im in...
^^^^^This.
The issue ends up being able to get enough stiffness when you applying the forces to the strut tower from so far back.
All of the reading I've done into Double A arm suspensions, suggests that they don't benefit from strut braces in the same way that McPherson strut style set ups do.
Because of the action of the suspension; the forces tend not to push the strut towers toward each other in the same way as a McPherson strut set up. Not saying that there isn't any benefit (there obviously is)just that the improvement is much less apparent.
Also, I can't really see a way to do it without tagging back to the firewall; which I'm really lax to do. I don't imagine many people are going to want to drill holes in their firewall to fit a strut brace.
Also the degree of complexity, and the number of parts; starts to push the price past what people are prepared to spend.
Edited by Daleo
I don't think you would significantly notice the strut brace in isolation, but when you pair it with the sway bars, coilovers, etc, it makes a difference.
Mine turns in significantly better than a number of others, and that was before I changed all the bushes, and before the under body bracing. It feels unbelievable, and I've had guys drive mine, and be passengers, and they can't believe the way it changes direction.
Sure, its no MX-5, but it's about 800kg heavier, and its designed for people who actually have friends/a life.
Just picked up my "Super Deluxe Cool-Style Spec Daleo Chassis Brace" from the post office! :woot:
I think I'll be doing some installation tomorrow morning...
Nice one mate; Auspost finally understand they must deliver MY parts the fastest. :yes:
Have fun mate; let me know what you think of the improvement!
I must say, this is simply and utterly
FANTASTIC!!!!!!!!!!
All of 10 minutes to fit it including jacking up the stag
Mine is completely standard apart from some really soft Japanese coil overs which came with the car, but my god what a difference it makes, confidently turns in, very noticible
Great work Dale ;)
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
