It will definitely fit a PNM35; I made one for Alex's (PN Mad) HKS fed beast in the last run.
The only issue will be delivery cost; I can get a shipping quote, and them we can go from there. Shoot me a PM to remind me, and I'll get back to you later in the week.
Cheers, Dale.
Dale
Sorry mate I wont be going ahead with this now, as I ended up making my own.
Lol! I didn't really do a pink one, yours is glossy, badass black; just like the rest.
Unwrapping it though... :whistling:
Devo. Here I was thinking I'd have a limited edition colour!
Lolz guise; if I'd realised the demand for pansy pink; I'd have doubled the price & brought out a limited edition...
Update; Braces and mounting hardware are bubble wrapped, in cardboard tubes and labelled for shipping.
Tracking documents all filled in to make life easy for the Post Office chicks, and if possible; they will be going to the Post Shop tomorrow, as I think they still do Saturday morning Parcel drop off.
If not; they will be going in early next week. I'll PM individually with a tracking number once they are on their way.
Thanks again for your patience and support with the group buy; won't be long until you're unveiling my shiny my black rod.
Enjoy lads.
Edited by Daleo
Enjoy lads.
time for another kind of bracing...3-point strut bar? :P
I have another part for stiffness! Need to talk to someone who has a M35 Chassis Jig though!!!!
Anyone got one!!! :domokun:
If I cannot find one I'll setup another Group buy.
P.S. This will take away the need for strutt brace......not that we needed a strutt brace anyway with our chassis but is a need!!! :cheers:
Edited by Jetwreck
It definitely makes a difference, so why not!
I am curious though how much of a difference the chassis brace is going to make when I've already got the strut brace.
Considering most of the steering & braking forces are channeled through the compression rod (piano); which is right next to where the brace mounts, its effect is quite pronounced.
Double A arm front ends don't load the strut towers in the same way that Macpherson strut arrangements do. Macpherson struts tend to push the strut towers toward each other as they compress; which effect camber & caster (and therefore contact patch).
Double A arms tend to direct the forces more efficiently upward; rather than inward, and the arms and shocks actually work better; so a strut brace has a lesser effect. Not NO effect, just LESS effect.
When you see how little support our chassis rails have (the crossmember is about a foot further forward); and how much force is directed diagonally back into them, you start to understand why such a simple brace makes such a big difference.
I know it might sound like I'm just pushing my barrow; but it does work, and it works well.
If I was able to fit the bar to your car, and get you to drive a course; then take it off (but not tell you), get you to drive the same course again, you'd know instantly that it was gone.
I have both strut brace and subframe brace. Strut brace did SFA but after taking out the stupid catt mounts (NA models) and fitting the subrame brace, it works wonders. Can not wait for the rear subframe brace
Glad you're happy Matt. ;)
where we up to with the orders for these things, i forgot all about it...
Daleo i think you can make me a front brace before my car is put back together, will it be different with a turbo and no dual cats etc ?
Hi Nate, I think I have a spare one; let me check tomorrow and I'll PM.
Should be fine; if you haven't already done the exhaust, you'll be able to work around the brace.
Scotty has a 3.5" system, with a 2" wastegate pipe running through there, with a brace fitted; so you shouldn't have any great issues.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
