yep got it mate..
list is updated and just so everyone knows entries are closed.
There are 11 spots remaining so if you would like to enter on the day get there nice and early to get yourself a spot.
  • Replies 247
yep got it mate..
I need to be there, fingers crossed
Sunday 15 July
Summary sunny.png Min 8 Max 17 Sunny.
Sydney area
Mostly sunny. Winds westerly 15 to 25 km/h.
DUDE!!!!!!!!!!!!!!! Hoe you can make it to say Gday. Just take the little scooter mobile like you did ages ago..... beep beep! HAHAHAHAH
The scoota is gone mate, to many powaahs for me to handle.
I reallly hope to make it mate, I still havent brought a car out in anger to a TEXI, its fun watching but if I remember my missgotten youth correctly doing power skids and slides is kinda fun.
it is fun, so get your ass into gear!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
